  #1
Old 12-02-2012
Mako144 is on a distinguished road
Hank on sails
Can I furl "Hank-on headsails? Cruising and/or Racing sails. I just bought a boat loaded with these, but the previous owner only raced the boat and I want to cruise.
  #2
Old 12-02-2012
Seaduction's Avatar
(retired)
Seaduction is on a distinguished road
Re: Hank on sails
You can get the luff re-cut by a sailmaker with a bolt rope sewn in to fit the furling system of your choice.
  #3
Old 12-02-2012
paul323 is on a distinguished road
Re: Hank on sails
Not really. A hank-on headsail generally has hanks which clip in to the forestay, and the sail can then be raised using the halyard.
A furling sail requires a roller-furler to be fitted to the forestay. This has one or two slots that the forsail fits into, for raising and lowering the sail - which you rarely do. It also has a drum at the bottom which allows the sail to be rolled (furled) and unrolled.
Thus a hank-on and roller furler are very different approaches. A sailmaker may be able to modify an hank-on headsail for a roller furler - a lot depends on the cut, age, etc as to whether that approach makes sense. And of course, if your boat does not have it, you would have to install the roller furling equipment.
Alternatively, many people prefer hank-on headsails, even cruisers! There are advantages and disadvantages to both approaches (as with everything to do with sailing). Personally I have a furler, and sometimes would have preferred hank-on sails....other days I delight in the convenience of a furler.
  #4
Old 12-02-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: Hank on sails
They do exist. My last boat - Columbia 43 - had a Mariner furling setup that furled hanked sails. The entire headstay rotated to accomplish it. It was a pretty early design and I never saw any advantage over a luff foil setup.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #5
Old 12-02-2012
overbored's Avatar
overbored is on a distinguished road
Re: Hank on sails
you can install Kiwi slide on the head sail and it will fit on the furler. however the racing sails are cut for max luff length and may need to be shorter to fit on a furler.
Reef Rite Down Loader with Kiwi Slides
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
You may post attachments
You may edit your posts
Track to Hank Jeff Bazz Cruising & Liveaboard Forum 8 06-09-2012 06:34 AM
Dealing with hank-on-headsails preservedkillick Gear & Maintenance 23 06-30-2009 01:05 PM
Need Hank on Jib for Catalina 27 TM snider General Discussion (sailing related) 7 05-07-2009 12:35 PM
Convert furling sails to hank on BlueWaterMD Gear & Maintenance 9 01-09-2009 02:25 PM
Hank on Sails w/ Roller Furling wind_magic Gear & Maintenance 22 10-06-2008 09:20 PM
SEO by vBSEO 3.6.1
