  #1
Old 12-05-2012
festivus is on a distinguished road
Cruising the Bahamas
I am interested in possibly cruising the Bahamas for a winter, but am unsure how I would fair with a sailboat that has a 7' draft? Would there be too many places I could not go or be constantly moving based on the tides? Would like some feed back by some experienced Bahamas cruisers. Also, has hurricane Sandy had any detrimental effect on depths in certain areas?
  #2
Old 12-05-2012
denverd0n's Avatar
denverd0n is on a distinguished road
Re: Cruising the Bahamas
7' is pretty deep for the Bahamas. There are some places you will not be able to go, some anchorages you will not be able to use.
On the other hand, it's not like you can't go anywhere. You will just have to be careful, and a little more aware of the water depth and the tides than someone with a shallower draft.
Haven't been there since Sandy, so I can't comment on that.
  #3
Old 12-05-2012
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
Earlier this year I saw some of the biggest super yachts in the world in the Exumahs. One was 280 feet! 87 meters! And a draft of 13 feet/4 meters. if you have a look on your chart from Georgetown and up north inside the fringing cays you will find there's plenty of depth, then from about Highborne Cay head due west till Toungue of the Ocean then up to Nassau.
If you have AIS you can track the super yachts and the local supply ships that run inside. And follow the magenta line
Sea Life
Notes on a Circumnavigation:
I write with an iPad and its spell checker changes some words. Beware.
  #4
Old 12-05-2012
Capt.aaron's Avatar
KNOT KNOWN
Capt.aaron is on a distinguished road
Mark is right. I was on a research vessel in the Bahama's that drew 8 and 1/2 feet. We were limited but not denied.
" Some are boat wise and some are other wise"
You may post attachments
You may edit your posts
Cruising to Bahamas on a 34' Catalina tashahacker Introduce Yourself 1 10-22-2012 05:15 PM
Cruising Bahamas mayaqueen Introduce Yourself 0 11-25-2011 09:43 AM
Cruising from NYC to Bahamas spacefight Introduce Yourself 8 07-16-2009 03:24 PM
Florida to Bahamas cruising egallant Crew Wanted 5 06-11-2004 05:20 PM
Best Bahamas Cruising Guide? helmsman Cruising & Liveaboard Forum 1 05-21-2001 05:49 AM
SEO by vBSEO 3.6.1
