Prop shaft material - SailNet Community
post #1 of 12 Old 12-05-2012 Thread Starter
Capnblu's Avatar
Prop shaft material
I have a 42' Tayana with a small perkins engine, a 4-108 (25-38 hp), a velvet drive transmission 2:1, and a Walter v drive. This set up spins a 1 1/4" shaft, 7' long, and I am thinking of hanging a Maxprop off the end of it. A PSS shaft seal will be fitted to the inverted stuffing box collar. What do you think would be an appropriate grade of stainless to make the drive shaft out of? The boat will live in the tropics.
Thanks Brian
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #2 of 12 Old 12-05-2012
chef2sail's Avatar
Re: Prop shaft material
aquamet 22
Change cutlass and collar at the same time
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #3 of 12 Old 12-05-2012 Thread Starter
Capnblu's Avatar
Is 316 appropriate?
Why, why, why?
Capnblu is offline
post #4 of 12 Old 12-05-2012
The stainless normally used is 304 and at 1 1/4 diameter that should be well strong enough with a safety factor well over three. A more common material is tobin bronze which has about the same yield strength but is more elastic. High strength alloys include Aquamet 22, 18 and 17; Monel 400 and K500 But they're overkill for your situation. more for special situations.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #5 of 12 Old 12-06-2012
I would never recommend any stainless grade for application under water. Obviously I will recommend titanium instead of things like aquamet or bronze, but they would certainly be preferable to stainless.
The issue with stainless is that it has different galvanic potential in and out of the water. So a stainless shaft actually galvanically attacks itself (this is what shaft zincs are for).
Greg
Stumble is offline
post #6 of 12 Old 12-06-2012
I once had a 304 stainless shaft corrode and pit so heavily that it had to be changed. It had a zinc on it the whole time. I would think that for the small difference in price it would be better to go with a higher grade of stainless or even monel or titanium.
Vindö 50
copacabana is offline
post #7 of 12 Old 12-06-2012
I know for the beneteau 42's shaft we just replaced the price for titanium was about $50 more than the aquamet price he had. And we delivered it with all the machining completed. He figured it was worth it just for the brag factor at the bar
Greg
Stumble is offline
post #8 of 12 Old 12-06-2012
Thanks Brian
Monel
Inboard Hardware: Propeller Shafts
..we replaced our 1 1/4" x 10ft with Monel..done by Kastel Bros. in St. Michaels,Md.
aa3jy is offline
post #9 of 12 Old 04-12-2013
One
Always tired
Old thread, I know, but I wonder what the price difference would be between a bronze (or stainless) shaft and one made from titanium.
And while we're at it, what about a 2 or 3 bladed folding propeller from titanium compared to one made from bronze? I know that those supercavitating ones are often made from titanium, but I'm talking a slow moving one attached to a reasonably light boat and few (<15hp) hp.
I probably won't be able to afford it, but I think it would be great to save a bit of weight down there, while at the same time not having to deal with bronze/brass underwater.
One is offline
post #10 of 12 Old 04-12-2013
tommays's Avatar
FWIW my original bronze shaft lasted 42 years and the Stainless one is doing just fine as you do have to be sure of there are certs on on the SS as substandard stuff is the cause of most problems
All my underwater hardware is original except the seacocks because they were gate valves
The 42 year old stuff that was changed because I count see sticking the new prop on the 42 year old shaft
The current flex-o-fold which just kicks azz in reverse
with the amount of bottom paint and other silly stuff I commonly see on props its no wonder stuff happens
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 07:50 PM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 09:46 AM
Propeller Shaft Packing Material mightyhorton Passport 0 12-07-2008 12:04 PM
Rudder Shaft Material hutch5151 Gear & Maintenance 6 11-05-2008 10:46 AM
Rudder shaft packing material erps Gear & Maintenance 3 07-27-2008 10:20 PM
