BVI chart/nav app - Page 2 - SailNet Community
 8Likes
post #11 of 94 Old 12-27-2012
TakeFive's Avatar
Re: BVI chart/nav app
I'm not sure if OP has headed out yet, but I have a couple minor things to add, if it's not too late. I'm heading down to BVI starting Jan. 5, so I've been checking a few of these things out myself.
I have the Garmin Oregon 400c, and plan to take it down to BVI in January. I have a $10 bicycle handlebar mount which can attach to the binnacle with a couple plastic tie straps. It's easily removed when done.
The 400c has charts already built in for the Caribbean, but they are very inaccurate (I'll demonstrate this below). I've debated buying a microSD upgrade from Garmin, but I have no idea whether it's any more accurate than what I already have. The inaccuracy is far worse than could be accounted for by the 3-year age of their chart. Why would Garmin intentionally put a grossly inaccurate survey into this device if they had better charts to provide on the chip? It just does not make sense, and as a result I'm not gonna buy a chip to find out. (I've heard that Garmin are absolute bast@%&$ about refunds.)
Here's how I did an informal test of the chart accuracy in the BVI:
Last December we went down for a land-based vacation on St. John USVI, and chartered boats a couple of days. One day we had a 23' powercat to go over to the Baths in BVI. Due to large swell and heavy chop, the captain hugged the coastline for much of the trip. We kept the Oregon 400c in my wife's purse to capture the track the whole day. His shoreline-hugging course gave me an outstanding opportunity to test the accuracy of the GPS and its embedded charts. I found many instances where the recorded track showed us significantly inland, and others where stopping points at shore were significantly off the shore.
For example, upon entering English waters, we had to check in at Jost Van Dyke's Great Harbour. I have exported this track to different charts to get an idea of the accuracy of the underlying charts.
First, the Oregon's embedded chart was off by almost a half nautical mile! The government dock where we stopped is about where the "D" in "Dyke" is located on the Oregon's chart, but you can see that our stopping point below is about 0.5 nm away from that point:
I exported this track and overlaid it on NOAA chart #25641, a 1:100,000 representation of the area (soundings in fathoms). Obviously the scale is not conducive to great accuracy, and I have overzoomed the chart for my screenshot. But you can see here that in this chart, the chart's government dock is located about 0.2 nm to the northwest of where we actually stopped:
A significant reason for the chart's inaccuracy is shown here:
As you can see above, the BVI part of that chart was based on a pre-1900 survey (back when BVI were still owned by Denmark)! Clearly the surveyors of that era did not have modern technology to assist their location. So these charts are not to be trusted for navigation.
Finally, I found much more modern (but still somewhat dated) NGA charts (soundings in meters), which NOAA allows you to browse free of charge but does not make available for download. Here is a screen shot or our track overlaid on NGA #25609, which appears to be much more accurate based on our stopping point and shore-hugging track:
This chart's survey was done in 1986, so it's much more recent, though still old enough to be cause of some caution.
FYI, NGA does publish periodic notice to mariners for critical changes to their charts, but they are relevant to ocean going vessels only, so you won't find important cruising information like Foxy's phone number there.
NGA 25609 gives a wide view of all the islands out to Anegada. But for closer-in cruising in Drake Channel, Chart 25611 gives a much better view at 1:30,000 and an inset of Road Harbour at 1:15,000 (but does not include Jost Van Dyke, which is why I did not use it here). [EDIT: A couple weeks after I posted this, NOAA removed these NGA charts from their website. I'm lucky I got them while I could! Unfortunately, this makes the instructions below somewhat moot.]
Now here's the trick for computer geeks: Although the NGA charts are not available for download (you can only view them with the Zoomify routines on the NGA site), there is a Python routine out there called DeZoomify that will download all the "tiles" that make up the chart, and stitch the whole thing back together into one large .png file. You need to have Python installed on your computer (it took me a couple tries to get a version of Python 3 that worked on my machine - hint: you need to run 32-bit Python even if you have a 64-bit OS). The Python routine takes several hours to run, but in the end you get a nice, high-resolution chart. Those not inclined to do this can do a Google search for the NGA chart, and you might get lucky and find someone else who uploaded theirs.
The next step to get the NGA chart to work in a chartplotter is to calibrate it and (preferably) convert it into a BSB/KAP file. I have struggled with this, because it seems the best tools are in Linux, which I don't have time to install. I have managed to get the .png files to load into SeaClear (that's how I took the screenshots), but these .png files cause it to be very buggy and it does unfriendly things to my computer's menus, so I don't recommend it.
Long story short, if I take the Garmin Oregon 400c on vacation with me, I'll only use it as an emergency backup for an on-board chartplotter (which I hope Sunsail provides), and will manually plot lon/lat onto their paper charts if I need to.
vtsailguy likes this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #12 of 94 Old 12-27-2012
fallard's Avatar
TakeFive, I bought an Oregon 450 2 yrs ago in preparation for a trip out of the USVI to the SVI. The 450 didn't have built-in detailed charts so I bought the US and Southeast Caribbean BlueChart g2 chips. The SE Caribbean chip is # HXUS030R.
I found the accuracy to be as good as the paper charts for the area. We threaded some reefs at Culebrita and elsewhere using paper charts and eyeball navigation, including reading the depths, until we established trust in the Garmin system. We ranged from St Thomas to Culebrita, Culebra, and Vieques and back by way of St. John with no issues. Actually, it was rather impressive.
BTW, I took a look at Great Harbour using my SE Caribbean chip and it provides a little more detail than your map views. I don't know if this microSD chip works in your 400c, but I would think so.
Your 400c has the same dimensions as my 450, which fit nicely in a drink holder on the boat we chartered.
fallard is offline
post #13 of 94 Old 12-27-2012
TakeFive's Avatar
Thanks, that's the kind of input that I was looking for. Now I need to figure whether Garmin could ship fast enough for me.
TakeFive is offline
post #14 of 94 Old 12-27-2012
fallard's Avatar
If you use the Imray-Iolare charts, note that they are not only not to NGA standards, but they are on a different datum than the US charts and your chartplotter, which is undoubtedly on WGS84. Read the fine print on the chart if you want to be precise, although there is only a very slight correction if you want to transfer a waypoint from the chart to your GPS.
fallard is offline
post #15 of 94 Old 12-28-2012 Thread Starter
Thanks. We're not going until Feb.
So far, my fav is the iSailor app. I'm thinking of springing for iNavX.
I'm not really worried about GPS nav capability, as much as redundant chart display and a planning tool. But things like ETA are nice to have.
ccriders likes this.
Jeanneau 54DS
Minnewaska is offline
post #16 of 94 Old 12-28-2012
BlueChart® Mobile app for iPad etc.
https://buy.garmin.com/shop/shop.do?pID=114005&ra=true
Links in very well with Active Captain.
Gerry
gtod25 is offline
post #17 of 94 Old 12-28-2012
HANUMAN
RobGallagher's Avatar
Although I appreciate your effort to warn others, I have to wonder about the scientific method you applied by stuffing it in the wife's purse.
I'm gonna ass-u-me that your wife's purse may have been down below, or stowed somewhere, or that there could have been other things in the purse that may have effected the GPS antenna like getting lodged under a cell phone, etc. That antenna needs a line of sight to the sky to work properly.
I would say this is not a very scientific method of judging a GPS unit. Again, I think you had the best intentions.
Respectfully.
RobGallagher is offline
post #18 of 94 Old 12-28-2012
TakeFive's Avatar
Respectfully.
Like many assumptions, it is a little off the mark. It wasn't actually a purse (I was trying to keep my wording simple) - it was her canvas beach bag that held hats, sunscreen, snorkels, etc., and was sitting in the cockpit the whole time. The GPS signal was perfectly fine - 8 or more satellites at all times. This GPS is extremely sensitive, and even gets a reliable signal in the middle of my house. I have no reason to doubt the reliability of the tracks.
Even if the track was a little off, it was exactly the same track on all three examples that I showed above, which means that the disagreement between the three charts can only be attributed to the charts. If you look at the track from the whole day trip, where we passed close by Cooper, Norman, Peter Islands, etc., it is clear that the NGA chart was significantly more accurate. The Garmin and NOAA charts showed us going over ground on numerous occasions, and the NGA chart agreed completely with our DR positions.
I believe that NGA makes the intelligence maps that guide our Navy vessels and cruise missiles, so I'm betting on them to have the best chart.
TakeFive is offline
post #19 of 94 Old 12-28-2012
TakeFive's Avatar
In my tests with the chartplotter programs, I was concerned about both datum and projection (though the latter not such a big issue close to the equator), so I carefully verified both. The NGA chart header says it is WGS datum, and the NOAA chart is as well.
I will heed your warning to watch out for the datum on any charts that are on the charter vessel. Are there simple offsets available?
TakeFive is offline
post #20 of 94 Old 12-28-2012
TakeFive's Avatar
Gerry
...and almost useless unless you have a Garmin chartplotter with WiFi networking capabilities. I was disappointed to see that this is not a freestanding chart plotter app that uses the internal GPS, but merely a repeater that takes the GPS coordinates though WiFi from a Garmin chartplotter - with purchase of a Garmin WiFi adapter.
I'll download the free app and see if it can make a wireless link with my Oregon 400c (which is touted as being capable of wireless sharing), but I'm not willing to buy the Garmin WiFi adapter to run the experiment. Leave it to Garmin to require a dongle add-on to override the iPad's built-in WiFi capability.
TakeFive is offline
Uses for Chart plotters and chart plotting software harbin2 Gear & Maintenance 41 10-07-2011 11:03 PM
Get a fix without using the chart (much)? davidpm General Discussion (sailing related) 8 07-11-2008 09:57 AM
Looking for G-chart pegasus1457 Cruising & Liveaboard Forum 3 09-10-2007 02:14 PM
Which chart software? groundhog General Discussion (sailing related) 20 07-10-2006 11:21 PM
CHART PLOTTERS SHIMSHON General Discussion (sailing related) 6 02-27-2001 07:54 AM
