Lifesling or Horseshoe for MOB - Page 4 - SailNet Community
 11Likes
post #31 of 36 Old 12-15-2012
Re: Lifesling or Horseshoe for MOB
Originally Posted by jrd22 View Post
IIRC, wasn't your son in that race Ron?
Yes, John... Luckily they realized prestart how bad it was going to be and bailed. They were struggling just getting the MELGES 32 to the start area.
Faster is online now
post #32 of 36 Old 12-15-2012
jackdale's Avatar
Originally Posted by flyingwelshman View Post
Would a Lifesling be classified as a 'lifebuoy'?
Not in Canada. Our lifebuoys are liferings.
jackdale is offline
post #33 of 36 Old 12-15-2012
snake charmer, cat herder
zeehag's Avatar
i have a ring. but who is gonna toss it to me when and if i fall ob from my solo sailed boat
formosa 41, cruising tropics
zeehag is offline
post #34 of 36 Old 12-16-2012
Over Hill Sailing Club
smurphny's Avatar
There has always been something that bothers me about the normal lifesling/horseshoe/ring MOB procedure. It seems unnecessarily complicated which is exactly what you want to avoid in an emergency. I've never understood why it's acceptable to expect the MOB to have to get out of a horseshoe or ring and get themselves into the lifesling horseshoe while panicked, possibly injured, in rough water and, in our area, suffering from hypothermia. I want something available (and USCG approved) to throw (throws well, even into wind) that will ultimately be what is used to winch them out of the water. Getting a line attached to it once the boat is close enough should only involve the MOB having to attach a snap on the end of a floating line. I also don't want to have to open a container of any kind to get to it. Manufacturers?
For getting back on the boat I have a long shackle permanently attached to the end fitting on the boom and a large snap shackle available to put on it to run the retrieval line through, then another snap shackle on a padeye on deck to feed to the sheet winch. Works on either side of the cockpit.
That sounds like a good system. What kind of gear do you have on the end of the line for the person to either sit in or grab onto?
chef2sail likes this.
smurphny is offline
post #35 of 36 Old 12-16-2012
chef2sail's Avatar
So the boyant line keeps the shackle from sinking? The MOB has to find the shackle and attach it to what? Ring on PFD. Can you lift dead weight with this. Suppose person doent have PFD with built in ahrness, where do you attach shackle?
Just asking? Sorry?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #36 of 36 Old 12-16-2012
smurphny's Avatar
Just asking? Sorry?
I think I'd also worry a bit about a topping lift carrying that much weight. And what do you do if the sail/boom is flapping about? A good sturdy whisker pole might be a better alternative, held up by a spinnaker halyard. Any pole idea like this could be a disaster in rough conditions. A simple rope ladder, amidships at the center of the boat's pivot point might be as effective as anything. Getting a heavy, incapable or out of shape (ie FAT) person back on a boat is certainly a major problem. I have installed a telescoping ladder on an emergency shackle that can be pulled down from the water but it is on the transom and would be a challenge to grab if I had to use it in a heavy sea. Any way you slice it, the best idea is to stay tethered.
smurphny is offline
Lifesling placement caroljeanly C25 and 250 3 02-06-2012 02:56 PM
Lifesling and MOB Strobe Bene505 Gear & Maintenance 20 02-26-2010 07:28 AM
Horseshoe Kalmia41 Gear & Maintenance 10 12-30-2006 01:14 PM
Horseshoe rescue bouy.. groundhog Seamanship & Navigation 20 10-01-2006 03:10 PM
Horseshoe on rope? Cony Gear & Maintenance 5 02-16-2004 03:32 PM
