Overloaded - Page 3 - SailNet Community
 6Likes
post #21 of 31 Old 12-19-2012
baDumbumbum
bobmcgov's Avatar
Re: Overloaded
Originally Posted by BubbleheadMd View Post
Bob,
Traveler was fully down.
This is a place where I think you could find some relief. On flat water or long swells, and when the wind is steady-hard, sheeting taut and traveler set outboard is a great strategy. But in messy chop, most boats do better with increased twist. Easy way to get that is to loosen the sheeting just a little and bring your traveler car up to the centerline.
That has two benefits: you are dumping excess wind up high, while the lower part of the main is still sheeted in to center and driving the boat; and you have room to lower the traveler during gusts, keeping the boat on its feet & not stalling the sail. When chop on the nose and gusty winds slow our boat down, that's when the keel quits lifting & we just start snowplowing sideways. If we open the leeches, foot off another 5 degrees, and play the puffs, we can punch thru the crud and generally get where we are going. Eventually.
BTW, the worst conditions for trimming we've found are after the big blow has started to taper, but the waves are still bouncing us around. We sometimes have to go back to full jib before we really want to, or the darned boat just won't go. Lots of twist and actively steering into the waves help, but honestly we haven't found a good answer for when the chop is bigger than the breeze.
Flybyknight likes this.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #22 of 31 Old 12-19-2012 Thread Starter
Chastened
Ajax_MD's Avatar
Re: Overloaded
Ok, I'll give your traveler method a try.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #23 of 31 Old 12-19-2012
Re: Overloaded
You might want to consider a jib down-haul and all lines running aft; but jack lines are probably on the top of your upgrade list.
Dick
Flybyknight is offline
post #24 of 31 Old 12-19-2012
Re: Overloaded
Here on the Chesapeake, some of us aren't done sailing.
Yesterday was 60F, partly cloudy and when I departed from the dock, it was blowing 20 knots varying rather widely between the west and northwest.
20 knots for me is fun, lively sailing. I reefed at the dock and loaded the 130% genoa. We shot out of my river as if from a canon. Downwind sailing, 6.5 - 7.5 knots.
Down the Rhode, into the West river, and out into the Bay. After a few minutes, I felt the boat being pushed even harder and I just knew that the uphill slog back into the West River was going to be some real work.
I turned the boat back west, and got my a$$ totally handed to me by a 32 knot wind. Boat's on her side, water splashing over the coamings, even with a two-speed winch, I simply couldn't grind that jib in. We were being shoved sideways by the waves and wind. The winch was intermittantly underwater. All leeway and no headway.
I gave up and fell off. Now we're under control and flying, but being driven further away from home, to the SE. This time, I want to tack and sail north to get lined up with the mouth of the river. It took two tries to get the bow through the wind, and I still couldn't get the jib in enough, but I was able to start the engine and drive us north, even with the mouth of the river, finally getting the jib sheeted in to the correct point.
We tacked again to sail WSW back into the river and I was able to disengage the engine. We tacked one final time to sail north, into the Rhode river to my marina.
I was disappointed that I chose an incorrect sail for the conditions, and disappointed that I allowed myself to be overpowered, and required the engine even briefly. Seriously, 32 knots deserves respect but I should have been able to handle this.
I intend to sail around Delmarva and if I can't handle a 30 knot breeze, I have no business being out there.
I have an auto-pilot, but it's not installed yet.
I do have a storm jib, but it was in my storage unit in town, not on the boat where it shoud have been.
I considered dropping the main, but felt that I would lose my ability to point, and require even more engine work to return to port. The Pearson 30 derives it's "drive" from the jib, and main balances the helm and provides pointing ability.
Thoughts?
Dude, you were sailing. It's freakin' Festivus and you're sailing.
Very nice. And time for a 110.
Chessie sailors (most of 'em) are seriously hardcore.
jameswilson29 and TheTardis like this.
smackdaddy is offline
post #25 of 31 Old 12-20-2012 Thread Starter
Chastened
Ajax_MD's Avatar
Re: Overloaded
Dick
Yes, a jib downhaul would be great. I have jacklines but they weren't installed at the time.
I also have some Wichard folding padeyes that I want to install in the cockpit to tether to.
Ajax_MD is offline
post #26 of 31 Old 12-20-2012
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Overloaded
Bubble;
And this post from a fella that recommended I'd need a 130% minimum fer a "starter' jib !!!!! (that *was* you, wasn't it?)
Good ta hear yer OK and had (some sorta) fun this late in the season.
Thanks for the reality check! Can I cash it at any bank?
deltaten is offline
post #27 of 31 Old 12-20-2012
I don't discuss my member
zz4gta's Avatar
Re: Overloaded
I run 1" nylon webbing from the stern cleat to the bow cleat. Yes, it would be difficult to get back on if I was at the end of my jackline, but the cleats were there, and all I did was buy heavy duty nylon webbing online. Cheap and easy.
The downhaul is easy. Block at the stem, bow cleat, whatever, then run a line up to 8-10' from the head. Done. I tried it on my boat, but it didn't work too well with the tuff luff.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #28 of 31 Old 12-20-2012 Thread Starter
Chastened
Ajax_MD's Avatar
Re: Overloaded
Originally Posted by deltaten View Post
Bubble;
Dude, you're not going to intentionally head out into 20+ knots like I do. You're also probably not going to sail as deep into the winter as I do. The Watkins also take a lot more breeze to get moving than my boat.
Trust me, my recommendation still stands, but you would also benefit from having a little 100% or 90% jib in case you get caught in a blow accidentally.
Ajax_MD is offline
post #29 of 31 Old 12-20-2012 Thread Starter
Chastened
Ajax_MD's Avatar
Re: Overloaded
Yeah, the webbing is what I have/borrow. I also have a pair of nice, Wichard folding pad-eyes. I want to install one in my cockpit sole as a tether anchor point.
Thanks for the jib downhaul tip. I'm going to rig that one soon!
Ajax_MD is offline
post #30 of 31 Old 12-20-2012
floridajaxsailor's Avatar
What strikes me most is this is a very honest and open assessment of a personal condition/challenge
no harm no foul
You to sound like you came through while learning even more about sailing in heavy winds
kudos to u
~JD
floridajaxsailor is offline
Boat in fatal capsizing was overloaded, San Diego authorities say - Los Angeles Times NewsReader News Feeds 0 07-28-2011 01:40 PM
Noob question re. overloaded sailing? Pesky General Discussion (sailing related) 13 08-09-2007 11:28 AM
Mayday - Overloaded with Emotion alan_21_us Boat Review and Purchase Forum 11 05-04-2006 04:10 PM
