Size Numbering on Winches - SailNet Community
 9Likes
post #1 of 14 Old 12-20-2012 Thread Starter
1982 Skye 51
obelisk's Avatar
I have always been in the dark about exactly what the numbers on winches mean. They seem to vary from brand to brand but also era to era. I found an explanation on another board here Winch Sizes are they all the same? [Archive] - Yachting and Boating World Forums that says the number is a multiplier of the force delivered to a standard winch handle. That sounds like a plausible explanation until they begin arguing whether Lewmar 54s are beefy enough for a 40' ketch's genoa sheets. I have a 51' sloop with nearly a 800ft2 genoa and I have Barient 36 primary winches. Now, they are from 1982 and the Lewmars in question are new but it seems to me that, somehow, these numbers do not line up or I am stronger than I think because my Barient 36s are more than enough to handle the load.
Can anyone shed light on the matter?
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
obelisk is offline
post #2 of 14 Old 12-20-2012
SchockT's Avatar
Re: Size Numbering on Winches
They usually refer to the power ratio, so a Lewmar 40 would have a 40:1 power ratio in 2nd gear. I believe Barient deviates from that, and I am not sure what their numbers are based on. but it might be the 1st gear power ratio. A barient 37 has a power ratio of 87 in 2nd gear.
If you are retrofitting you should be looking at drum diameter and base diameter. I would think that those Lewmar 54s would be much smaller and less powerful than what you have now.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #3 of 14 Old 12-20-2012
MarkofSeaLife's Avatar
Dock
They are age related.
I have Lewmar 50's as primaries, but i should have 53's cos thats how old i am, but i feel like getting 70's or 80's
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #4 of 14 Old 12-20-2012
There really is no consistent naming convention for winch sizes. Some manufacturers tie it to power, others to drum size, some I have no idea what they are referencing. Generally winches with the same drum size have roughly the same power, but not always.
Greg
Stumble is online now
post #5 of 14 Old 12-21-2012 Thread Starter
1982 Skye 51
obelisk's Avatar
Schock,
That would make sense for the high/low gearing. Once you drop into that low gear it seems like you could rip the sail in half.
After 30 years, and nearly 100,000nm the gears/pawls/etc. in the Barient 36s show no signs of wear and tear, I am just trying to satisfy my own curiosity--the only thing I replaced was one needle bearing that I dropped while cleaning and lubing a few years back. Every time I break one apart I am amazed at the ruggedness and ingenuity contained inside these (and all) winches! Thanks for the replies.
obelisk is offline
post #6 of 14 Old 12-21-2012
Aspiring to be a Mexican
sww914's Avatar
I always thought it was the number of stitches it would take to sew you up if you fell on it face first.
sww914 is offline
post #7 of 14 Old 12-21-2012
chucklesR's Avatar
For what it's worth, the correct answer is "It Depends"
No standards were used across makers and years.
chucklesR is offline
post #8 of 14 Old 12-21-2012
chef2sail's Avatar
Here I thought it was the total number opf springs and pawls you could lose overboard when servicing them.
Great explainations
Dave
jimrafford likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #9 of 14 Old 12-22-2012
Master Mariner
capta's Avatar
When I ordered springs and pawls from Lewmar, the guy on the phone suggested cutting a hole the size of the winch base in a cardboard box and slipping it over the winch before dismantling, to contain the tiny bits.
Thought it was a good idea and I'll pass it along.
chef2sail and jimrafford like this.
capta is online now
post #10 of 14 Old 12-23-2012
chef2sail's Avatar
Thats exactley how I do it. I save my cutout, but sometime the springs are related to Murphy
Parkville, Maryland
Our blog-
Does size matter?? Wheel size, that is... Undadar Gear & Maintenance 9 09-17-2011 07:39 PM
Hull numbering scheme johnbanfield Pacific Seacraft 7 11-27-2010 05:47 AM
Slip size and boat size. rikbass Announcements and Suggestions Box 12 09-14-2010 02:52 PM
self tailing winches but what size saurav16 Gear & Maintenance 24 07-11-2007 09:06 PM
sail size to boat size ronbrockman General Discussion (sailing related) 0 09-25-2001 04:10 PM
