Gybe set, gybe drop - SailNet Community
 3Likes
  • 1 Post By Faster
  • 1 Post By nolatom
  • 1 Post By PaulinVictoria
post #1 of 6 Old 12-31-2012 Thread Starter
uvs
Gybe set, gybe drop
What does it mean? ( Gybe set / Gybe drop )
I see this words at RYA Race Training Exercises booklet, page 16.
Explain me, please.
uvs is offline
post #2 of 6 Old 12-31-2012
Re: Gybe set, gybe drop
A gybe set is when you round a windward mark, gybe and then set the spinnaker. This is done to get you on the preferred tack sooner, but delays the set slightly because you can't preset the pole.
A gybe drop is similar, at the leeward mark you gybe before dropping the spinnaker.. also known as a windward takedown.. generally you clear the pole and fly the kite without the pole until the gybe/rounding , then the spinnaker is quickly pulled down to windward.
jackdale likes this.
Faster is offline
post #3 of 6 Old 12-31-2012 Thread Starter
uvs
Thank you.
uvs is offline
post #4 of 6 Old 12-31-2012
As said, it's a bit slower because you have to get the pole up there in a hurry after the jibe.
But often it's a great way to get clear air if most of the others are just bearing off and not jibing.
And downwind with spinnys, clean air for the whole leg is worth lots more than brilliance, cunning and great boatspeed but dirty air.
Faster likes this.
nolatom is online now
post #5 of 6 Old 12-31-2012
Remember you're a womble
PaulinVictoria's Avatar
They are both terms used to describe making the foredeck guy's life a lot more panicked
SloopJonB likes this.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #6 of 6 Old 12-31-2012
tommays's Avatar
On a windward/ leeward race which tend to have legs in the 1 mile range around here unless the course is setup really bad or there has been a wind shift so big the race should be re-started the gybe-set is pretty much SLOW
If we do what they call a navigator race around here when there could be all kinds of wacky rounding its killer IF you can do it right
We call the other a weather take down and it is handy in big wind as once you can get the chute unloaded enough to trip it off the pole its easy to drag it around the headfoil and let the Genoa help you drop it
The other advantage is how much less stuff will need to be moved on the next hoist on a short course
Most of this is make or brake by the helm person NOT turning the boat until the chute is under control
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
do you gybe? QuickMick Seamanship & Navigation 42 06-02-2011 08:23 AM
accidental gybe QuickMick Seamanship & Navigation 34 02-21-2011 06:18 PM
Gybe-EZE Mc51 Gear & Maintenance 13 02-28-2009 12:07 PM
accidental gybe peter428 General Discussion (sailing related) 23 06-09-2008 08:55 AM
gybe preventers Kacper Seamanship & Navigation 18 04-08-2007 11:16 AM
