winching up the mast, - Page 2 - SailNet Community
 8Likes
post #11 of 17 Old 01-07-2013
Omatako's Avatar
Re: winching up the mast,
We take three wraps around a halyard winch and then off to the capstan on our horizontal windlass. That way the line is arrested by the halyard winch in the unlikely event that it accidentally jumps off the windlass.
My wife can winch me (130kgs) to the masthead with her big toe on the deck switch and is not standing under me. I have a second halyard to belay myself as I go up.
Coming down is as easy as slipping the halyard on the halyard (mast) winch.
I will, before I go cruising be putting mast steps on because to me this is still the best option.
Capt. Gary Randall likes this.
Arthur C. Clarke
Omatako is offline
post #12 of 17 Old 01-07-2013 Thread Starter
I like mast steps, just have a problem with screw points sticking inside of mast, cause with MY luck something is going to get messed up.
AirborneSF is offline
post #13 of 17 Old 01-07-2013
Broad Reachin'
kwaltersmi's Avatar
Lots of good advice in this thread and elsewhere on SN about mast climbing. We ALWAYS use the sheet winch as for the primary, and have used the mast winch for a back-up safety halyard. However, I prefer keeping the deck below the mast clear of people in case of an accident, so using sheet winches for both primary and secondary is preferred.
You can read the details of our technique here: Up the Mast
Catalina 34
kwaltersmi is online now
post #14 of 17 Old 01-07-2013 Thread Starter
Good sound advice. Thanks, All!
post #15 of 17 Old 01-07-2013
Omatako's Avatar
I use "blind" rivets, don't know what they're called where you live, could be pop rivets. The Monel 5mm rivets are easily strong enough to hold the weight of a human being, I have used them for years on steps and never had a failure. They have a blunted end inside the mast that will do no damage to sails, halyards or electrics.
The Youtube clip below shows two 5mm Monel rivets fitted in 1.6mm steel plates and tests them to 730lbs before failure. Normally a mast step would be fitted with a minimum of three and mostly 4 rivets and the material thickness of both the mast section and the step material would be thicker than 1.6 so the shear would be enhanced. You would probably have a safety factor of 300% or more depending on the number of rivets used.
Just be sure not to use ordinary aluminium rivets, they're nowhere near as strong as Monel.
Just thought this may help.
Arthur C. Clarke
Omatako is offline
post #16 of 17 Old 01-08-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
I found the Hake video very informative. I particularly liked the trick with the bridle cable. I was trying to figure out how to rig something like that up ; but was stuck on "hardware", not "soft-ware" LOL
deltaten is offline
post #17 of 17 Old 01-09-2013
If the person ascending the mast can do some of the climbing it will take a lot of work off the winch and person winching.
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
The secret to sailing is good judgment. Good judgment comes from experience. Experience comes from bad judgment.
okapi3 is offline
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
Winching my boat into the dock? TakeFive General Discussion (sailing related) 25 06-03-2011 07:57 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
