Retractable Bowsprit DIY - Page 4 - SailNet Community
 1Likes
post #31 of 42 Old 01-09-2013 Thread Starter
Re: Retractable Bowsprit DIY
Originally Posted by jameswilson29 View Post
If you were to design your own sprit, a great feature would be an articulating sprit with the sprit pivoting around the stem area and a curved track on the aft, so you could position it to the gunwale on either leeward side when flying the spinnaker, thus gaining additional valuable projection of the pole to windward.
Wow, that would be trick.
Though on my Cat. 27, if you draw a line parallel to the centerline, between the stem fitting and the foreword pulpit rail stanchion, there isn't a lot of cross-section there. So I don't think I can get much more swing to starboard, presuming I mount it on the port side, than it will take just to get it to intersect the C/L of the boat at a decent projection. That was one reason the teardrop cross-section of the spar, I have, seemed so "ready made".
Thanks for the thought James.
Next time I'm down at the yard I'll check that possibility out.
Cheers for now,
Joel H.
Joel H. is offline
post #32 of 42 Old 01-11-2013
A few posters mentioned using the spin pole instead of bothering with a sprit, and that has been mentioned recently on SA as well, but I just don't understand how the tack of the sail is attached to the end of the pole, how the pole is kept from rising up (tweakers? downhaul?), and how it would be jibed. Could someone explain?
Cheers for now,
Joel H.
Haha that would be pretty cool, mini-650 style! I guess using a spin pole would allow you to create the same effect for some deeper angles downwind...
Just out of curiosity, what kind of angles can one expect from a typical/basic cruising spinnaker tacked to the bow pulpit on an older boat like the op's? Can they be used for light wind beam reaching or even hotter?
peterchech is offline
post #33 of 42 Old 01-12-2013
No different from tacking it anywhere else, though I usually use a soft spectra loup at the pole end for attaching the tack line block... Some might want to add a light line from the shackle trigger back inboard if you need to blow the tack, but I never bother with that, just seems like something else to get fouled...
The use of a foreguy and afterguy is essential, IMO, to really stabilize the outboard end of the pole... With the additional downward pull of the tack line, you should see very little movement of the pole... I'm a big believer in the use of a foreguy and afterguy led back to the cockpit when cruising, especially shorthanded, even with just a whisker pole... FAR less drama, IMHO...
With an inner forestay like mine, jibing is definitely a big production... I basically have to snuff the sail, then re-rig the pole on the other side, and re-set...
Ideally, you want the pole closer to horizontal than in the pic below... On this afternoon in the breeze was coming up to the point where carrying the chute was getting marginal, and I'd just lowered the pole end down from where it had been, in an effort to snug everything up a bit, and minimize the oscillation... but I dropped it pretty soon thereafter, I seem to recall, it was starting to get a bit hairy as the seas began to build a bit more...
Check out the sailmaker's websites, everything you need to know is to be found there...
North Sails: Downwind Sail Performance Guide
JonEisberg is offline
post #34 of 42 Old 01-12-2013
Yeah, sounds cool in theory, but I just don't see how it's really practicable on anything other than a pure race/sport boat, with an absolute clear foredeck...
I had all I could do to configure using my spinnaker pole as a fixed sprit... With all the additional foredeck clutter found on many recreational boats - large mooring cleats, anchors on rollers, foredeck hatches, windlasses, tenders often stowed on foredecks, etc - it's just not gonna be possible on many boats...
post #35 of 42 Old 01-13-2013
There are different ways to do this, there are one short hand sailor here in Norway who is using a system he is calling ASOP (Asymmetric Spinnaker with Oversized Pole)
He is using a spinnaker boom with length J + 1meter.
He uses three lines attached to the tack of the sail.
-Tack line
-Two afterguy's
All three spliced into one snap shackle
The sail is tacked in front of the head stay (the usual way) with a adjustable tack line going to a cabin top winch).
Setting the sail is done as usual.
The pole is set on the windward side the afterguy is put into the spnnaker boom as yuu would do with a spinnaker afterguy.
The tack line is eased and the windward guy is hauled in to pull the tack to windward
Gybing the sail is done in this sequence (outside gybe)
-ease the afterguy while hauling in on the tack
-When the tack is hauled in do the outside gybe
-After the gybe - dip the spinnaker boom and set on new tack
I set my assymetric on a bowsprit but use a normal length spinnaker boom the same way as decribed above to pull the tack to windward for downwind runs.
Here is a video of this gybe
Take down
knuterikt is online now
post #36 of 42 Old 01-13-2013
SchockT's Avatar
That's an interesting setup, although 3 minutes, 3 trips to the bow, and leaving the pole loose on the deck for one gybe seems a bit messy to me!
The douse in the second video is what we call a "letter-box drop", and it is a good way to control the chute and keep it from getting fouled on the way down IF you have a loose footed main. Throwing the halyard overboard to ensure it runs smooth works well. I do it once in a while just to get the twists out, but you have to remember to rinse the salt out of it if you care about your halyards!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #37 of 42 Old 01-13-2013
Don't know why he had to go 3 trips on the fore deck for that gybe.
When I gybe with my asymmetric I do only one trip to shift side for the spinnaker boom (or stow it if not needed on the new tack).
We do letter box drop with the spinnaker regularly on the boat I race on.
The asymmetric on my boat is set in a furler so that's a different game.
post #38 of 42 Old 01-13-2013
Furler for Asymmetric and Code 0
The question about furler for Asymmetric and Code 0 has been raised in this thread.
I have a Facnor FX2500 with a AFX kit so I can use the same furler for both the Asymmetric and the Code 0.
This is the tack of my Code 0, the bowsprit is in it short position, also notice the bobstay (adjustable) to deal with the extra load of the Code 0
This is the Asymetric on the furler with the AFX (the torsion stiff rope is the black rope going from the furler.
In this picture the tack is eased to get the luff to windward because we sail almost DDW.
The tack has to be hauled in before furling
The Facnor system use a central furling line attached half way up the luff going to the torsion stiff rope. I have no experience with the top down furler - but I will try next summer (I only have to disable the top swivel with a dyneema lashing to convert)
In this picture the have use the spinnaker boom and a afterguy to get the sail to windward - less wind than i the previous picture so that helped fill the sail.
post #39 of 42 Old 01-14-2013
I see. So ur basically setting up like u would the symmetrical spinnaker, except you have one extra line, the tack line. (Foregut/after guy is the same as guy and spin sheet, right?)
Sort of eliminates the point of a cruising assymetrical though, which is to simplify downwind sailing. By the time I set this up for my cruiser, I might as well just throw up the symmetric and have less complication to deal with!
Still, it allows deeper angles for those with asyms so it's cool in that sense. Eliminates the only advantage that symmetrical kites hav on the race course. I haven't seen one flown off a pole yet at the race course, but maybe I just haven't been looking hard enough. maybe I should pretend I invented the technique ;-)
post #40 of 42 Old 01-14-2013
I see. So ur basically setting up like u would the symmetrical spinnaker, except you have one extra line, the tack line. (Foreguy/after guy is the same as guy and spin sheet, right?)
I have a usual spinnaker boom setup for dip poole gybe. (Topping lift, Foreguy/downhaul and Pole heel lift)
There are six lines on the sail;
The four standard lines for asymmetric (halyard, adjustable tack, sheet x 2 rigged for outside gybe)
+ guys x 2 attached to the tack (the furler in my case).
Sort of eliminates the point of a cruising asymmetrical though, which is to simplify downwind sailing. By the time I set this up for my cruiser, I might as well just throw up the symmetric and have less complication to deal with!
Don't know if I agree with you.
Setting the asymmetric.
-clip furler onto tack line & guy's (use soft shacles to attach guy's so they can also be rigged after the sail i set)
-clip on halyard
-From cockpit
-Tighten tack (done by hand) to pull the furler out on the end of the bowsprit
-Hoist
-Unfurl while taking in on active sheet
If I need to use the spinnaker pole (normally light conditions DDW).
-set spinnaker boom on mast
-Put the windward guy in the jaw if the spinnaker pole
-Adjust Topping lift & Foreguy
-Winch in on guy while easing tack
To gybe (can do the hole gybe w/o leaving the cockpit)
-ease the guy while winching the tack tight (cabin top winch)
-Stabilize the spinnaker boom using Foreguy & topping lift
-Execute a standard outside gybe
-rest pole if needed on new tack.
I use this for cruising, seldom sail straight lines - normally I sail different courses with the asymmetric up.
So this give me a wider usable angle in which I can use the asymmetric.
-No need to switch between spinnaker/asymmetric
-On less sail to carry and spend money on
-Fore deck work with boom only when I need/want it
As i wrote i previous post, there are short hand racers around here who use it for racing.
One reason you haven't seen it on the race course can be
-rating rules
-type of racing (windward / leeward favor symmetrical)
Irwin 30 Bowsprit piccadeli Irwin 0 02-02-2010 11:53 AM
Bowsprit glegh Sailboat Design and Construction 5 04-13-2009 11:08 AM
Thru hull sensors - retractable? db27513 Gear & Maintenance 9 10-11-2008 12:56 PM
Beneteau retractable keel terry-gufshoz Boat Review and Purchase Forum 3 03-05-2004 07:12 AM
mirage 236 retractable keel skprmsb2 Gear & Maintenance 1 11-01-2001 05:42 PM
