Retractable Bowsprit DIY - Page 5 - SailNet Community
 1Likes
post #41 of 42 Old 01-15-2013
Re: Furler for Asymmetric and Code 0
Originally Posted by knuterikt View Post
The Facnor system use a central furling line attached half way up the luff going to the torsion stiff rope. I have no experience with the top down furler - but I will try next summer (I only have to disable the top swivel with a dyneema lashing to convert)
Just curious, how would one "disable" the top swivel to convert your present system to a top-down furler?
Seems to me the only way these top-down systems work, is to have the dedicated bottom furling drum, where the tack attachment swivels independently of the torsion line... What am I missing, here?
Nice looking boat, btw.... What is she?
JonEisberg is offline
post #42 of 42 Old 01-15-2013
On the Facnor AFX system there are two swivels
Top swivel is kind of strange
The torsion rope is fixed at one end, at the other end the halyard is attached, allowing the torsion (anti twist) rope to turn without turning the halyard.
The head of the sail is attached to a dyneema strop that rotates on a bearing on the outside of the swivel housing.
So when you furl, the torsion rope is turning but halyard and head of sail is standing still.
At the tack end the torsion stiff rope is fixed to the furling drum, so it rotates when the drum is operated.
The tack of the sail is attached to a dyneema strop that rotates on a bearing on the furler drum (same as head).
The asymmetric has a thin dyneema line attached to the luff - mid height (central furling line) that is also attached to the torsion stiff rope.
So when you furl the sail the dyneema line is furled and the sail is furled from mid luff.
So if I prevent the head attachment from swiveling I have the same top down system as Selden, Bamar and others use, just interested to find out what works best (w/o buying new kit).
Documentation here http://www.facnor.com/uk/technical_s...ns_2012_uk.pdf
Tack of the asymmetric
Head of the asymmetric
Tack of the Code 0
Head of the code 0 with the standard top swivel.
Furler in the position used for the Solent jib
Maybee video's is better
Facnor ASYM-FX (at 0:27 you can spot the central furling line)
Bamar top down furler
Beneteau First 38
knuterikt is online now
Irwin 30 Bowsprit piccadeli Irwin 0 02-02-2010 11:53 AM
Bowsprit glegh Sailboat Design and Construction 5 04-13-2009 11:08 AM
Thru hull sensors - retractable? db27513 Gear & Maintenance 9 10-11-2008 12:56 PM
Beneteau retractable keel terry-gufshoz Boat Review and Purchase Forum 3 03-05-2004 07:12 AM
mirage 236 retractable keel skprmsb2 Gear & Maintenance 1 11-01-2001 05:42 PM
