Changing Oil - an easier way? - Page 4 - SailNet Community
 10Likes
post #31 of 58 Old 01-10-2013
Puget Sound Pounder
kellysails's Avatar
Re: Changing Oil - an easier way?
Originally Posted by Minnewaska View Post
I previously agreed with this approach. However, I can't get enough oil out the dip tub, due to the canting. Therefore, my turbo is acting up. If the turbo wastegate hangs up in the closed position, I am equally at risk of blowing the motor, not to mention the $3k turbo even if I catch it early enough.
I'm just going to have to monitor this new exposure. I've always been very good at checking the motor prior to departure.
Yup, that seems like the logical thing to do.
kellysails is offline
post #32 of 58 Old 01-10-2013
Glad I found Sailnet
Bene505's Avatar
Originally Posted by Quickstep192 View Post
"They've always worried me a bit, as any break in the hose or leak in the fittings could put the entire contents of the drain pan in the bilge while underway"
You're concern (which I share) is justified. If that hose breaks while underway, the likelihood of destroying the engine is high. The hose on mine is very thick walled which also prevents it from collapsing under vacuum.
We have a similar setup. I discovered that the hose was partly worn-through from rubbing against the engine. Repalced it with a new hose that's a bit longer and so doesn't rub against the engine anymore.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #33 of 58 Old 01-11-2013
Tundra Down
downeast450's Avatar
My Atomic 4 uses the following Moyer Marine accessory. The extraction hose is capped, held against the engine "space" bulkhead with a hose clamp and is out of the way. I use a small hand suction pump that I connect to the extraction hose. I never counted the number of strokes! Really! The hand pump and delivery hose easily fits into a gallon zip loc bag then into a flat tupperwear container. No big deal. I do like having the extraction part of this set up permanently mounted to the engine as per Moyer's kit.
Moyer Marine Online Store
I switched to fully synthetic oil. Going by appearance and viscosity It stays cleaner longer and changes easily. It may give me a few rpms, too. We don't use the engine very much so changes aren't frequent. It is more expensive to use Mobile-1 or an equivalent but I am protecting my A-4 and reducing the frequency of this little chore.
Down
(KTAS_05_90) Oil change kit
Oil change kit
This kit installs permanently into the 3/4 pipe-thread opening in the oil pan, just forward of the fuel pump. Handpump is not included.
downeast450 is offline
post #34 of 58 Old 01-11-2013
As I said earlier, I just bought the Moeller extraction pump at the end of the season. No maiden voyage yet.
I just started wondering how one keeps oil from dripping out of the extension tubes while being stored? This thing going to become a mess maker?
Jeanneau 54DS
Minnewaska is offline
post #35 of 58 Old 01-11-2013
Yanmar do not provide an oil drain plug for their GM series engines. I looked for a place to tap in a thread and fit a quick drain but can't see anywhere with enough metal.
Sucking it out through the dipstick hole is the only choice. I added about 10 inches of thin copper tube to the flex hose of the vacuum pump and it seems to get most of the oil out. At least what I put in approximately equals what comes out! I change the oil and filter every six months regardless of hours run ( boat used most of the year) and am happy that it is staying clean enough.
arvicola-amphibius is offline
post #36 of 58 Old 01-11-2013
Originally Posted by arvicola-amphibius View Post
....At least what I put in approximately equals what comes out!
I suppose that only means you didn't burn any oil. To know you got it all, you should be pulling out an amount near equal to its published capacity.
Excellent plan. Making maintenace as easy as possible is a secret to proper maintenance.
Jeanneau 54DS
post #37 of 58 Old 01-11-2013
captrice
Jabsco makes a 12 volt Vane pump which is reversable and does a good job of pumping the oil out and right back in. If you are lucky enough to have a drain plug on your oilpan a simple wire reinforced hose ( size ? ) installed correctly with chaffe in mind running up to the pump mounted next to your engine. Make sure you have enough hose on the discharge/intake side to reach your container. West Marine will probably have to order the pump as they do not normally stock it in most stores. I have used one for 10 years
and can change the oil and filters on my cats (4gals.) in about 15 minutes. It's very clean and efficient.
captrice is offline
post #38 of 58 Old 01-11-2013
I use this on all of my cars and the boat. It makes oil changes a breeze and I have never had one fail. You can buy them from amazon, but I have never seen these in a store.
FUMOTO ENGINEERING
On the boat I use one that has a nipple to attach a hose to pump the oil from the bottom of that pan.
peoples1234 is offline
post #39 of 58 Old 01-11-2013
Old as Dirt!
svHyLyte's Avatar
I know the Moeller pump gets great reviews, but they have one big drawback, for me... If you're off on a extended cruise during which you'll be changing oil, that's an awfully bulky item to have to tote around on a smaller boat...
I've been using a 12v pump made by Quik-Drain for years, it's been great... Unfortunately, the company is no longer in business, but you might still find some laying around at some vendors... Or, Harbor Freight sells a small 12v fluid pump for around $30, one of those would do the trick, as well...
My Perkins has a dedicated tube out of the sump for changing oil, don't know why more manufacturers don't do something similar, so my system is permanently installed, all it takes is flipping a switch... Agree with the others who are nervous about replacing the drain plug with a hose fitting, if you're gonna go that route, be very careful and go with a top quality hose like Aeroquip, and make certain there's no possibility of chafe, etc...
We have a similar arrangement on our generator. Our drain "hose" however is high pressure hydraulic hose that is armored with a woven metal mesh exterior cover that was/is standard equipment on Panda Generators and ensures the hose will not suffer chafe failure. One could easily adapt the application to any other motor.
svHyLyte is offline
post #40 of 58 Old 01-11-2013
T37Chef's Avatar
I don't follow you?
Gota store the oil somewhere? I guess I just don't see that as a big drawback as you say.
Shawn
T37Chef is offline
easier diesel bleeding Frogwatch Gear & Maintenance 24 11-07-2012 12:01 PM
Easier then safe boating class? deniseO30 General Discussion (sailing related) 5 05-12-2010 11:48 AM
Cutter easier to heave to? Ilenart General Discussion (sailing related) 5 06-12-2009 05:41 PM
Easier going @ $$$ The Daily Sail $$$ NewsReader News Feeds 0 04-11-2006 08:15 AM
Making single handing easier stephens84 Seamanship & Navigation 3 08-01-2004 04:50 PM
