LED's Integrated Into Boats Popular? - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 01-13-2013
SchockT's Avatar
Re: LED's Integrated Into Boats Popular?
LED lighting is the way of the future, not just a fad! There is no getting around the energy efficiency, and the quality of the light they produce is getting much better. They are perfect for power conscious sailors.
Hopefully the trend of powerboats lighting up every nook and cranny of their exteriors with them IS a fad that will die off. To me there is nothing more obnoxious as a power boater who feels the need to light up a 50ft radius around his boat on an otherwise beautiful starry night. And then they end up running their generator to power all that lighting, just to add insult to injury!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #12 of 16 Old 01-13-2013
Master Mariner
capta's Avatar
The first thing we changed to LED was the galley lighting. We went from 6 amps to not even a noticeable meter deflection!
Running lights were next and boy, what a difference in power consumption. After doing the spreader lights, we now use them whenever we want, as long as we want, for the slightest reason. Compared to the tractor bulbs I've used for so many years, the LED spreader lights are brighter and have already outlasted the old bulbs.
We really hate the fancy yachts that come into the anchorages with all their underwater LED's on at nite, though. Too intrusive. I would like one, under our fishing station; I believe it would be a real boon to night fishing.
As we find fixtures, we are replacing the interior lights as well. The LED's are indeed power savers and I IMO well worth the cost.
One note; when changing the red and green running lights, you must use the bulb of the correct color; white is not the proper bulb to use.
Another thing I've been told regarding LED bulbs is that heat will destroy them, so don't leave your anchor light on 24/7.
capta is offline
post #13 of 16 Old 01-13-2013
I bought LED flashlights in a dollar store. They are bar shaped and have a window of light, like as if they are for the guy guiding airplanes on the runway but smaller. I put 4 of these inside my cabin and made a dimmer for them. its pretty simple, 4 components: 1 voltage stabiliser, 1 adjustible resistor, 1 normal resistor, 1 capacitor. And the dimmer itself uses barely any energy.
Total cost 20$
I also replaced the running lights including their casings with LEDs. Total cost 100$ or so. As above poster sais, i should have used colored LEDS though. My white LED with green casing looks very bleuish...
With 200W of solar panel and the only other energy usage being being the standard devices; gps, autopilot, depthsounder, vhf and my laptop, i now have an excess of energy and dont need to bother turning off any lights in the morning or whenever
Arjen is offline
post #14 of 16 Old 01-19-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I can't say for boats.. I have replaced lights in my car and house with LEDs.. the house saw a big drop in the electric bill.
Work has also been converting from incandescent and HIDs to LED. I work in a theatre, so when you are running 120K watt rig.. the LEDs really cut down on the power consumption.
When I get my cruiser, I will replace all the incandescent with LEDs and like above, add enough to the cabin that I can make it cozy, or bright enough to need sunglasses (not really)
I am tempted to add one or two underwater lights too. Would be nice in the bahamas to see what is swimming beneath you at night
mad_machine is offline
post #15 of 16 Old 01-19-2013
hallucination's Avatar
On newer boats, (at least the one I have) there is not ANY incandescent or fluorescent lights ANYWHERE. I was surprised that the Deck Light was a LED array. I just wish that designers would pay more attention to using the proper CRI/color temp. Most of the LEDs used are WAY to cold, like in the 6500k range. By far the best place for an LED is at the top of the mast.
hallucination is offline
post #16 of 16 Old 01-19-2013
chef2sail's Avatar
Originally Posted by LeMerovingian View Post
Hello,
I am curious if the aftermarket LED wave has cooled off or not? What's your opinion on them? Useful? Extravagant? I feel when implicated into the interior like in newer models they are a great improvement exterior to much but still has it's place........,
Aftremarket wave....hardly. Doesnt make sense to have anything other than LED in most cases since they have figured away to reliev the ve the problem of the "glareiness" color of them. The energy savings makes them a no brainer.
Alpenglow Lights
I am a big proponeny of Alpenglow lights.
Lemerovingian,,,little confused by your profile. What type of boat are you trying to outfit?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
CPT or integrated with CP SanDiegoChip Gear & Maintenance 1 03-27-2011 10:02 PM
How to test led's at masthead?? thekeip Gear & Maintenance 6 06-11-2010 03:32 PM
New Lighting Fixtures with Sensibulb LED's Willis Gear & Maintenance 4 03-23-2009 02:00 AM
45 CC cutters are the most popular cruising boats...huh? JohnDrake Boat Review and Purchase Forum 27 11-29-2003 09:37 AM
Integrated Radar/GPS/Plotter flicker Gear & Maintenance 1 10-05-2003 08:48 AM
