hook scraper - SailNet Community
 5Likes
post #1 of 12 Old 01-13-2013 Thread Starter
stevieb7
hook scraper
I read in don caseys book to use a hook scraper for the hull bottom paint removal. Does anyone know who sells a quality scraper?
stevieb7 is offline
post #2 of 12 Old 01-13-2013
Re: hook scraper
Stanley makes a line of scrapers, have a look at the link below
Stanley Scraper - Lowest Prices & Best Deals on Stanley Scraper - Pronto.com
One of the issues with the standard Stanley scraper blades that I've used is that they are slightly convex along the edge, with is exactly what you don't need when working on a convex shape like the outside of the hull.. you get a very narrow contact area. However on that page there looks to be a variety of blade shapes.
If you have access to a metal shear, interestingly an undressed sheared edge of SS makes a pretty good scraper for varnish. It doesn't last all that long but you can cut plenty from scrap SS.
oysterman23 likes this.
Faster is offline
post #3 of 12 Old 01-13-2013
Seņor Member
PorFin's Avatar
Re: hook scraper
Stevie,
Local hardware stores & big box stores carry them. That said, having used a hook scraper for bottom paint removal I'm absolutely certain that I'll never try it again. If you decide to give it a shot, then do yourself a really big favor -- wear a complete bunny suit, head cover, gloves, a quality dust mask, and eye protection. Spend the extra money on a carbide scraper, and buy plenty of spare blades. Might as well buy some Wheaties as well, 'cause it's gonna be a real arm workout.
A method many here recommend (personally I cannot, since I've yet to try it myself) is to wet sand with a drywall sanding pad and pole. Waaaaaay, way less dust and easier on the arms.
Jgbrown likes this.
________
'85 BYB Vagabond 39
PorFin is offline
post #4 of 12 Old 01-14-2013
Capnblu's Avatar
Re: hook scraper
Learn to burnish a burr onto your scraper, use a piece of HSS or cobalt steel. It takes some practice, but when you get the hang of it, you will only need to redo it 3 or 4 times for a whole hull, instead of every 3-4 minutes of standard sharpening. The bottom paint will seem to explode off the hull. Works well for teak decks and varnish removal too instead of sanding. Brian
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #5 of 12 Old 01-14-2013
Capnblu's Avatar
Re: hook scraper
Here is a link to give you an idea what I mean.
Scrapers Part 1
Why, why, why?
Capnblu is offline
post #6 of 12 Old 01-14-2013
Re: hook scraper
+1 to the carbide scrapers. Also, go slow, once you get the paint to "break"(a small match removed down to gel-coat, then using one edge of the scraper, move forward in small increments, don't try to over-reach. I often find that 1/4" is the most I can do, the scraper glides along the gelcoat, and and removing 1/4" all the way down to gel-coat reduces dust, effort and time it takes versus trying to take full width scrapes.
Jgbrown is offline
post #7 of 12 Old 01-14-2013
One of None
deniseO30's Avatar
Re: hook scraper
Capn is dead on right! Keep a file handy; the "edge" only lasts a few dozen scrapes on fiberglass! You can get a quick and easy "burr" with a file but the right way is as described in the link Capn provided. without that edge.. hook scraping is nearly impossible without super person strength!
Oh.. and they work really well on teak! But teak is full of silica and takes the edge off cutting tools quickly.
My last project!
deniseO30 is offline
post #8 of 12 Old 01-14-2013
Capnblu's Avatar
Re: hook scraper
As I learned to burr the edge on my scraper, I found I could go further, and further before having to redo it. I am now to the point that a 42' teak deck only requires 3 sharpenings. sharp a a scalpel, and stays that way!
Why, why, why?
Capnblu is offline
post #9 of 12 Old 01-14-2013
Re: hook scraper
Carbide :-)
No filing. Sharpen with a knife stone, but they last an hour between flipping.
Can't imagine doing a big boat with a regular scraper.
Jgbrown is offline
post #10 of 12 Old 01-14-2013
Capnblu's Avatar
Re: hook scraper
Haha Jg, you must be a real glutton for punishment, the burr is the secret not the hardness of the scraping blade. If you use HSS steel, or cobalt steel to create the burr, you will be amazed at what you can accomplish. The burr is as sharp as a scalpel, and carbide can't be sharpened or manipulated to achieve the same results, especially with a knife stone. Also, it helps to hone the edge before burring up to 2000-3000 grit. The higher the better. I like 5000 grit myself.
Why, why, why?
Capnblu is offline
motoring with the hook down Barquito Gear & Maintenance 7 10-14-2010 05:52 PM
hi from the hook chrisncate General Discussion (sailing related) 2 07-18-2010 07:25 AM
Somewhere to drop a hook ... Boomberries Introduce Yourself 2 04-05-2010 08:42 PM
TV reception on the hook hns1934 General Discussion (sailing related) 20 02-26-2010 01:41 PM
Red Hook question dpinorm Chartering 6 12-11-2001 06:09 PM
