Overpropped; What to do? - Page 4 - SailNet Community
 7Likes
post #31 of 32 Old 04-19-2013
Re: Overpropped; What to do?
The sweet spot is hull speed and maximum torque without current and head winds. Resulting in a smaller engine to supply the needs.
Max torque is at a lower rpm on electric motors, diesels and then gasoline engines, in that order.
I've been thinking that Bombardiers new passenger jet, is gearing the turbines prior to the combustion turbines, in an effort to reach maximum torgue at the desired cruising speed.
Pitch is a combination of the angle of attack of the blade and its surface area. If you cut only its surface area, theen the blade will achieve a lesser distance thru the water than before it was cut.
sony2000 is offline
post #32 of 32 Old 04-20-2013
tommays's Avatar
NO NO NO
It is a motor with mechanical fuel injection which is THE problem being resolved
The mechanical fuel injection system will input excessive fuel based on throttle setting regardless of the RPM the motor makes
The extra fuel does bad things to motor and it is as simple as that
Any displacement hull will have a Huge prop slip number due to the need to NOT drag a bucket size prop through the water when sailing
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
overpropped vs underpropped groundhog Gear & Maintenance 45 12-19-2012 10:20 PM
