Whisker pole questions - SailNet Community
post #1 of 11 Old 01-13-2013 Thread Starter
1. Does one attach the whisker pole to the mast with the retractable pin side up or down? Does it matter?
2. I gather that one can sail by the lee of the headsail with it poled out to windward? How much is advisable - 160 degrees apparent with pole to starboard?
3. If I'm singlehanded sailing wing and wing with pole to starboard and I want to jibe.... can I leave pole there, jibe to port broad reach with pole and boom on leeward (starboard) side? (I know it may be against racing rules and not perfectly elegant, but it would be a lot simpler/safer than getting up on the foredeck and changing it).
Thanks!
matthewwhill is offline
post #2 of 11 Old 01-13-2013
Re: Whisker pole questions
1. Poles should hang ON the pins... ie jaw opening up.
2. 160 is pretty wide for 'by the lee'.. the whisker pole won't help the 'close to accidental gybe' aspect of running by the lee, and in fact if you're willing to run by the lee the whisker pole is not as necessary... the jib will stay full more easily on its own. So as far as by the lee angles the whisker pole is not a factor. Wave action, mainsail sheeting and driver's attention are all bigger issues.
3. I suppose you could, but you'll not be getting proper trim on the jib with the pole left on. If it was a short gybe to avoid an obstacle followed by an early gybe back then OK... Also if it's windy and you end up rounding up out of the gybe you might 'stuff' the pole end in the water - a good way to break something.
Faster is offline
post #3 of 11 Old 01-13-2013 Thread Starter
Thanks faster,
For my second question I meant can I have the boom to port, whisker pole to starboard and then sail at 160 degrees apparent (coming from aft and starboard) - by the lee of the headsail, not the boom/mainsail....
Would I be able to get lift from the leech of the headsail with reverse flow?
post #4 of 11 Old 01-13-2013
Originally Posted by matthewwhill View Post
Thanks faster,
OK.. terminology confusion.... 'by the lee' means that the apparent wind is coming over the quarter of the same side the BOOM is on. There is no 'by the lee' wrt to the jib. Strictly related to the mainsail position.
Yes, if you're not running DDW and on a very broad reach, then that's why you use the pole on the windward side, to prevent the jib from collapsing so often.
Also if you're running that deep 'lift' isn't really in the equation - you just want drag...(projected area)
Faster is offline
post #5 of 11 Old 01-14-2013
Master Mariner
capta's Avatar
I crossed the Indian and Atlantic Oceans with the Yankee poled to weather and the gene and main to leeward, not quite DDW, maybe 15 to 25 degrees. Balanced the boat amazingly well and it was very comfortable. I did have twin head stays which helped a lot, but I believe the fore and aft head stay roller rigs I see on many cruising boats today would work just as well.
capta is online now
post #6 of 11 Old 01-14-2013
I don't think it really matters much, but Forespar seems to recommend the opposite...
It does matter, however, if you want to store the pole on the mast, which I think is the way to go on a cruising boat... Unless you're using a piston-style fitting at the mast end, hanging that end of the pole with the pin up will not allow the pole to be brought to a vertical storage position...
JonEisberg is offline
post #7 of 11 Old 01-14-2013
Senior Smart Aleck
jameswilson29's Avatar
1. It does not matter with a jib because the sheet will not usually release up out of the jaws as a spinnaker sheet does. A spin pole should always be jaws up.
2. Yes, but when the apparent wind is abaft the beam, the mainsail directs airflow to the jib, not the other way around, so you should concentrate of keeping the jib full and drawing, not the main. Further, on most masthead rigged boats, in most conditions, the jib will have greater sail area and drive than the main.
Thanks!
Yes. Here is a video of me doing the exact thing in reverse (pole to port), first wing and wing, then a broad reach with pole in the same position:
Wing and wing:
Then broad reach:
jameswilson29 is offline
post #8 of 11 Old 01-14-2013 Thread Starter
Thanks everyone-
James Wilson: when you say "jaws up" does that mean pin up? ie opening of jaws up? or am I confused
Do you want the spinnaker sheet to fly up and away once you release the pin?
post #9 of 11 Old 01-14-2013 Thread Starter
Also:
It doesn't look like you have a topping lift or a fore-guy? Should I infer that these aren't always necessary?
post #10 of 11 Old 01-15-2013
Senior Smart Aleck
Thanks everyone-
Yes, jaw up, so ideally the line will fly up when the jaw is open...
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 01:38 PM
Whisker Pole Aurea Cal 0 10-15-2010 11:14 PM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
Using A Whisker Pole Dan Dickison Learning to Sail Articles 0 04-23-2001 08:00 PM
