Hacking a trolling motor into a towed type generator - SailNet Community
 4Likes
post #1 of 44 Old 01-15-2013 Thread Starter
Has anyone seen this done?
Its cheap, 12 volts, and draws about 40 amps. so if run wired to a diode then the house bank and powered up I speculate it could possibly pump out 10 amps. Total guess.
Might need a bigger prop, or one with a shallower angle, but I don't see why this couldn't work and if I'm right why more cheap sailors like myself haven't done it. It's even cheaper than solar if it works!
peterchech is offline
post #2 of 44 Old 01-15-2013
guitarguy56's Avatar
Re: Hacking a trolling motor into a towed type generator
You might be thinking something like this? I see a lot of drag for a small sailboat...
guitarguy56 is offline
post #3 of 44 Old 01-16-2013
I have no idea whether it would be practical, but I would guess your estimate of 10 amps is exceedingly optimistic...
I use a towed generator from Hamilton Ferris, a fantastic piece of gear. I'm always surprised more cruisers on passage don't use water generators, though they do inhibit your ability to fish...
However, as effective as they are, mine generally puts out roughly 1 amp per knot of boat speed, perhaps a bit more above 5-6 knots... I probably see spurts close to 10 amps periodically, but getting that sort of performance consistently out of a cobbled-together arrangement with a trolling motor seems unlikely to me...
JonEisberg is offline
post #4 of 44 Old 01-16-2013
Tow Generator at its Best - YouTube
Damn, that vid should be titled "Tow Generator at its WORST", that is one nasty looking set-up... The prop should not be breaking the surface like that, and whatever line they're using is totally unsuitable, becoming kinked and whipping around like that...
post #5 of 44 Old 01-16-2013 Thread Starter
I guess the point would be not to tow it with a line, but rather to mount it directly off the transom using its existing shaft as a solid mount.
post #6 of 44 Old 01-16-2013
tommays's Avatar
I know a local person that runs the class 40 dragon and there top shelf land/sea or whatever water generator does NOT become efficient until there above 8 knots at which point the output is massive
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 44 Old 01-16-2013
No doubt you're thinking of the hydrogenerators from Watt & Sea...
VERY pricey, the cruising version is still over $5K, if memory serves... "Call for Quote" is rarely an encouraging sign... (grin)
Watt and Sea Cruising Hydrogenerator
Bernard Stamm recently was forced to retire from the Vendee Globe, due to the damage/failure of his water generators... Every boat in the race is using them, that's how dependent these guys (and girls) have become upon them...
post #8 of 44 Old 01-16-2013
The problem is that using a motor as a generator is that the voltage output is dependent on RPM so below a certain RPM you will not get any charge. Which is why motor charging systems use an alternator, which provide a more consistent voltage.
And you would definitely need a bigger prop or at least a hi-thrust version.
A better system would be a prop driving an alternator but would be much more DIY.
A quick google will show you that it is not really feasible.
tschmidty is offline
post #9 of 44 Old 01-16-2013
chef2sail's Avatar
What is the drag these produce on speed? I have often looked at these and wanted more informatuion on them.
Jon could you expand on your experiences with the Ferris one, I have seen them.
dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #10 of 44 Old 01-16-2013
Remember you're a womble
PaulinVictoria's Avatar
Get a used electric troller and try it. I think the Watt and Sea ones start at $3200 or thereabouts.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
trolling motor mcnabbstacy Gear & Maintenance 3 07-29-2012 11:14 AM
hacking a trolling motor hertfordnc Gear & Maintenance 1 10-26-2008 04:05 PM
Does anyone use a Electric Trolling Motor poopdeckpappy Gear & Maintenance 23 10-19-2007 09:08 PM
trolling motor generator dodgeboatguy Gear & Maintenance 3 07-19-2007 03:22 PM
trolling motor generator dodgeboatguy Gear & Maintenance 0 07-18-2007 10:24 PM
