Head conversion options? - SailNet Community
 2Likes
post #1 of 17 Old 01-15-2013 Thread Starter
rbyham's Avatar
I am close to purchase of a boat whose head is currently a direct discharge unit. I would like to convert it to something that can be used. I don't want to go the porta potti route. I would prefer something I could pump out. Are there options that avoid all the work and cost of plumbing a holding tank but still give me pump out capability? Thanks.
rbyham is offline
post #2 of 17 Old 01-15-2013
Re: Head conversion options?
The West Marine site has a tech notes type of section that has some decent diagrams and options for adding a holding tank and related plumbing, maybe start there.. But it sounds like you want to pump out at each use, but not overboard? Not a practical plan.. A holding tank is a necessary evil unless you go to a composting head.
Faster is offline
post #3 of 17 Old 01-16-2013
Lake Superior Sailor's Avatar
They make portapottys that pump out! NO matter what you decide It can work well if you take care of it!..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #4 of 17 Old 01-16-2013
Old Salt
Since pumpouts are few and far between in our neck of the woods , we went with a supersize porta-potty . The toilet part is large and comfortable and the holding tank is about 5 gallons .
We can pump it out or carry it offboard if needed. When we are far enough offshore , its easy enough to dump overboard .
5 gallons does us for about a week .
gypsygypsy is offline
post #5 of 17 Old 01-16-2013
no longer reading SailNet
Alex W's Avatar
This was just discussed in this thread and you'll find some useful responses:
Installing a traditional head from scratch
Alex W is offline
post #6 of 17 Old 01-16-2013
pdqaltair's Avatar
If you edit you personal information to include your location and boat it helps responders. In this case, we would know how big the boat is and where you sail (regulations vary).
We like to help, and this information helps us.
SloopJonB likes this.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #7 of 17 Old 01-16-2013
Go for the composting head, either Airhead.com ( expensive ), natures head( less expensive), or C-head( far less expensive), or better still make your own composter( around $25 or less).
Brent Swain is offline
post #8 of 17 Old 01-16-2013
Old enough to know better
You don't say what size the boat is, that can make a difference, but you can try this:
SEALAND Head at West Marine
Otherwise, and this would be my suggestion, either an Air head, or a Nature's head composting toilet. Seems to me to be the best option to not have have to run plumbing.
miatapaul is offline
post #9 of 17 Old 01-16-2013
Senior Moment Member
SloopJonB's Avatar
The hands down best head setup I've ever used was on a BVI charter boat. The holding tank was built under the hull deck joint behind the head.
The inside face of it was vertical so it made a vertical "wall" on the hull side in the head compartment. I would assume the actual tank was wedge shaped as a result.
The beauty of it was that it was gravity draining - when you were in open (legal) water you just turned the valve - no pumping, no macerator, no nuthin' and it took up pretty useless space as well. Totally easy to rinse with fresh water as well - just open the valve and stick a hose in the deck fitting.
Definitely the way to go if you can fit it in your boat.
Minnewaska likes this.
SloopJonB is offline
post #10 of 17 Old 01-16-2013
Omatako's Avatar
The European plastics are now going this way as standard. A friend just bought an Oceanis 40 from Beneteau and both their holding tanks are gravity drainers. I'm thinking of converting mine the same.
Arthur C. Clarke
Omatako is offline
Pearson 31-2 fresh water head conversion littlelizzy Pearson 6 09-20-2012 02:11 PM
Stolen sailboat crashed in Hilton Head pool - Hilton Head Island Packet NewsReader News Feeds 0 06-22-2012 03:50 AM
Yachting: Cup teams go head to head NewsReader News Feeds 0 08-06-2011 04:30 AM
Head - electric conversion or new electric head snw Gear & Maintenance 5 04-29-2007 08:07 AM
Cal 27 Pop Top Conversion DonaldAdams General Discussion (sailing related) 2 07-11-2006 12:24 AM
