Emergency leak repair - Page 3 - SailNet Community
 5Likes
post #21 of 24 Old 01-17-2013
Re: Emergency leak repair
I like the foam bases Fortress TruPlug. Seems like an ideal solution to holes, better than wood plugs. For the shaft I keep a split bicycle inner tube. It worked great when I wanted to pull my shaft gland waterborne. If you have a flexible tube on the hull penetration it would work there just great if it failed. Also anything that you could stop a leak by wrapping. Blue water sailers talk about plywood to cover a stove in window port in a storm. USIA sailing has a standard for a watertight bulkhead for the bow section e.g. ramming something. I was able to modify my open chain locker with a gasgeted panel that I can screw down to make it watertight. (filled it with a hose to check).
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #22 of 24 Old 01-17-2013
OOPS
On the foam plugs they're carried by Forespar not Fortress.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
post #23 of 24 Old 04-05-2013
johnnyquest37's Avatar
We check and exercise our thru-hull fittings once a month. At each thru-hull is a plastic bung. In our collision kit:
Balsa bungs, assorted sizes
Ball peen hammer
A tube of 3M 5200
Fiberglass cloth
A roll of wax paper
Epoxy putty sticks
Nails (with the ridges)
Crowbar/wrecking bar - so I can tear away cabinetry if I have to
Also onboard are spare hoses, hoes clamps and all types of tape. We have a manual bilge pump, an electric bilge pump, a shower sump pump, and a hand-held pump, plus buckets.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #24 of 24 Old 04-05-2013 Thread Starter
This is a great add!
Jeanneau 54DS
Minnewaska is offline
Large dinghy leak repair Petar Gear & Maintenance 1 07-14-2012 08:30 AM
leak from P bracket repair nodders Gear & Maintenance 6 05-06-2012 09:07 AM
I need help with Emergency Fiberglass Repair lowryjim Gear & Maintenance 6 10-21-2009 07:51 AM
Tricky Shaft Log Leak Repair JonG Gear & Maintenance 7 04-27-2009 09:00 PM
Emergency Fiberglass Repair lowryjim General Discussion (sailing related) 0 10-30-2004 09:23 AM
