01-22-2013
Senior Moment Member
Re: Do all Beneteaus have iron keels?
Originally Posted by mad_machine
One of the benefits of iron is that after sanding your keel down to bare metal, you can always weld more metal onto it to fill any rust eaten hulls. This also works for any missing "chunks" taken out from groundings. You can then grind it back smooth and prep with modern paints and sealers and go on your way
If you take a "chunk" out of an iron keel in a grounding, smoothing the keel out is going to be the least of your concerns.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
