Do all Beneteaus have iron keels? - SailNet Community
 4Likes
post #1 of 28 Old 01-20-2013 Thread Starter
I like some of these boats but the iron keel is simply a deal breaker. Curious to see if any were made without iron keels.
Catalina 36 MKII
Florida
HeartsContent is offline
post #2 of 28 Old 01-20-2013
blt2ski's Avatar
Re: Do all Beneteaus have iron keels?
There is probably a First series boat or two with an lead keel. But the typical Oceanus/cruising style boat, will be iron. Same with Jeanneau. Most are iron, there is a sunfast model or two out of lead. In fact, many if not most of the what I would call chevy model style european boats, have gone to iron, more due to cost, lack of lead in Europe. That is not to say that there are not european built boats with lead.
Frankly, a well designed iron keel will work as well as lead. On the other hand, rust thru does need to be delt with upon occasion.
Marty
She drives me boat,
I drives me dinghy!
Last edited by blt2ski; 01-21-2013 at 10:22 AM. Reason: correct "lead" misspeel, thank you faster!
blt2ski is offline
post #3 of 28 Old 01-20-2013
I think some of the US built Benes may be lead, pretty sure it was available as an option. But nowadays iron doesn't have to be a dealbreaker, but many feel as strongly as the OP about that.
Marty - typo in line one....
Faster is offline
post #4 of 28 Old 01-21-2013
CBinRI's Avatar
Some of the older firsts were made with Iron and some were made with lead, even the same models. Don't know about the new ones.
CBinRI is offline
post #5 of 28 Old 01-21-2013
Senior Moment Member
SloopJonB's Avatar
Check out this link before you make iron a deal breaker - the bolts in iron are easily replaceable for a few $. Modern coatings make iron far less of a maintenance problem than years ago.
Keel J bolt replacement in lead keel
SloopJonB is offline
post #6 of 28 Old 01-21-2013
Our 1998 Beneteau Oceanis 352 has a lead keel. I don't know about later models.
davmarwood is offline
post #7 of 28 Old 01-21-2013
Having own a 1999 Bene since new, i can say you are missing out good boats thinking that iron keels are a deal breaker. I barrier coated my keel when the boat was new before the boat ever hit the water for the first time. 3 years ago I had a small bubble of barrier coat lift and under it was rust, about the size of 3 inch circle. Ground it down to shinny iron and re-barrier coated it. took all of 45 min's. Haven't seen another speck of rust. 13 years of ownership 45 min's of keel maintenance, That would be a deal breaker for me.
Never Forgotten
bubb2 is offline
post #8 of 28 Old 01-21-2013
Epoxy coated iron keel? What's the worry?
Jeanneau 54DS
Minnewaska is offline
post #9 of 28 Old 01-21-2013
ASA and PSIA Instructor
I had some complaints about my First 305 but the iron keel was not one of them. Prep and epoxy it properly once and then it is just routine upkeep, as with lead.
Sent from my DROID RAZR using Tapatalk 2
sailingfool is offline
post #10 of 28 Old 01-21-2013
Old as Dirt!
svHyLyte's Avatar
Depending on the model and year you are looking at will determine whether a lead keel was available. For most Beneteau yachts, however, certain items were original Buyer options including keel type (lead/cast iron/deep/shoal etc), mast type (keel stepped/deck stepped/standard, mid- or tall rig, two or three spreaders), water tankage and type (stainless/bladder), back-stay adjustors or none and type (screw/hydraulic) etc. etc. etc. Finding a specific configuration to suit your specific requirements may be possible but will be problematic unless you are willing to cast a very wide net.
As a practical matter, the cast iron keels have proven to be very durable and are rarely subject to difficulties. If treated/maintained properly, they are no more problem than their lead cousins. Our boat, a 1986 era First 42, is fitted with the shoal draft (6.5') cast iron keel and absent a few rust spots from time to time at our tri-annual haul-outs (which are easily treated) we've had no issues with the keel at all.
FWIW...
svHyLyte is offline
opinions re: epoxy vs. plastic hulls, lead vs. iron keels ArgleBargle Sailboat Design and Construction 33 08-12-2008 10:21 AM
Iron Keels Versus Lead Keels twofish81 Gear & Maintenance 14 12-02-2007 01:58 PM
Iron Keels Versus Lead Keels twofish81 Sailboat Design and Construction 4 11-30-2007 10:55 AM
Iron Keels mogul11 Boat Review and Purchase Forum 3 07-08-2002 03:36 AM
Prepping Iron Keels Tom Wood Gear and Maintenance Articles 0 08-28-2000 08:00 PM
