Bayliner Bucaneer Cruise Speed Under Power - Page 2 - SailNet Community
post #11 of 12 Old 01-23-2013
Re: Bayliner Bucaneer Cruise Speed Under Power
Originally Posted by mad_machine View Post
yes, this is not a gas engine. Diesels thrive on running at WOT fully loaded. It is what they are meant to do
Not sure I want to run at WOT for extended periods, but you are certainly safe running at 85%.
Catalina 34
chuck53 is offline
post #12 of 12 Old 01-23-2013
chucklesR's Avatar
Keep in mind that while diesels like to work, they like to work at no more than 90% continuously (recreational boats are fitted with either light or medium duty diesels, not the tug boat type continuous rated ones).
Your MD7A is rated at 13hp max at 2600 RPM. I'd not run it above 2340 RPM for more than 30 minutes.
If the Volvo and Bayliner engineers fit it out right you should reach your hull speed (
Your B 275 is 24.33 feet at the water line, max speed is 6.65 knots) at that RPM.
Volvo gives two different reduction ratio's - you didn't say you have the S drive (folder) so I'll go with the 1.91 ratio of the other model.
At 1800 rpm that's 942 RPM at the prop.
942 RPM * 11 inch pitch * .48 (standard slippage per Dave Gerr for a displacement boat) = 414 feet per minute - or 6.9 feet per second.
you guessed it 4.7 miles per hour
Funny how math just seems to work out isn't it.
At 2340 RPM
2106 rpm at the prop, 11 pitch = 926 feet per minute 15.4 feet per second ( 9 kts).
Since you can't go 9 knots, you are over pitched. Generally your engine came with a 14x9, just saying.
chucklesR is offline
Which dinghy sailboat faster Snipe or Bucaneer 18 ? Curtisfromcarlsbad General Discussion (sailing related) 6 06-26-2011 01:00 AM
Gemini 105MC Slow speed under power TexasWill Boat Review and Purchase Forum 81 07-26-2010 11:26 PM
Cruise speed with Volvo MD6A diesel talbot Gear & Maintenance 7 10-26-2009 11:07 PM
bayliner 25 Alanjp Cruising & Liveaboard Forum 1 02-27-2008 10:50 PM
Electrical Power Recharging Options for Extended Cruise Stormer Cruising & Liveaboard Forum 9 10-10-2006 03:07 PM
