Can someone explain roach to me? - Page 3 - SailNet Community
 7Likes
post #21 of 22 Old 01-29-2013
Re: Can someone explain roach to me?
John Lecher , author of the self steering book and an aircraft engineer, said without full length battens a roach increases the performance of a mainsail from zero to three percent, but is responsible for 80% of sail repairs.
SVTatia likes this.
Brent Swain is offline
post #22 of 22 Old 01-30-2013
SchockT's Avatar
Originally Posted by knuterikt View Post
What do you call this? Furling main with roach
I'm no big fan of furling mains but that problem has a solution.
Do some of those battens go right from the boom to the leech? It looks like the ones in the HR pic does! That must be $1000 worth of battens! And what happens if your furling fails and you have to take the main down the old fashioned way? Battens that long would be pretty awkward. It seems like with the increased risk of the battens fouling inside the mast, and the disturbance the batten pockets cause to flow across the sail the benefit of the little bit of roach it gives you is hardly worth it.
Brent Swain likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
Roach and How Many Battens? Sabreman General Discussion (sailing related) 24 07-24-2011 07:36 PM
Extra large roach mainsail klubko Gear & Maintenance 32 11-14-2010 07:24 AM
adding roach AllThumbs Sailboat Design and Construction 28 10-10-2008 03:49 PM
Can a sail with too much roach be cut down without ruining It's shape? Sabre66 General Discussion (sailing related) 2 05-29-2007 07:43 PM
Roach or not mainemandean Gear & Maintenance 26 01-05-2007 01:19 PM
