Sailors rescued 900 miles off shore.. - Page 2 - SailNet Community
 8Likes
post #11 of 39 Old 02-01-2013
sunfish?junior?
Re: Sailors rescued 900 miles off shore..
Originally Posted by mad_machine View Post
WNA is no place to be in a small boat. I do agree that I am glad there was no loss of life. The Coast Guard make it all look so easy
From what I read the boat is a respected "blue water" boat. Built in Costa Rica ? She is not an aircraft carrier or tanker, What size was she and what factors made up her demise? I am not know about her size or the exact model year and condition. Was her core rotten? Did "rotten to the core" come from apples or boats? Good day, Lou
Lou452 is offline
post #12 of 39 Old 02-01-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Winter on the North Atlantic is one of the more unforgiving places to be. If you look carefully as most commercial ships, you will notice the draft numpers for and aft? Used to be (not sure if it still is) that the bottom most number would be labeled "WNA" as in... Winter North Atlantic.. Loading to this line would put the ship at her shallowest depth and giver her the most freeboard to survive the waves from the storms that churn this part of the ocean up during the winter.
While I have no problems with sailing across the atlantic.. it is not something you should do from late fall till mid-spring
Lou452 likes this.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #13 of 39 Old 02-01-2013
sunfish?junior?
Now we have one strike WNA .. Rotten to the core is for apples. Like many boats she may have had a balsa core with rott. Can anyone tell what year and length she is. Good Day, Lou
Lou452 is offline
post #14 of 39 Old 02-01-2013
Senior Moment Member
SloopJonB's Avatar
When I was a kid we sailed from Liverpool to Montreal in early November in a 22,000 ton Cunarder. It was the last run of the season, even for a ship that size. It was scary - the seas were like mountains even from 50 odd feet up. We weren't even allowed out on deck.
Being there in a small boat in JANUARY is simply Darwinism in action.
SloopJonB is offline
post #15 of 39 Old 02-01-2013
美国华人, 帆船 教授及输送
Great that there was no loss of life, of course... But I'd hardly call setting such a beautiful boat adrift at sea, still floating on her lines, and with the main mast still in the boat, an entirely "happy ending"...
Sure would be interesting to know more details on this one...
Agree. I assume every captain knows they will never see the boat again if the EPIRB is activated.
If I were the captain in this situation, I would make the the boat sink before being rescued. I remember a couple year ago there was a sailor (I think his last name was Chan) from Seattle, abandoned his boat in the middle of India Ocean. He did his deed and watching his boat sunk into the ocean. Hard but must be done.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #16 of 39 Old 02-01-2013 Thread Starter
TIBURON 36 sailboat specifications and details on sailboatdata.com
Clay AA3JY
s/v 'Tango'
Cabo Rico 34
aa3jy is offline
post #17 of 39 Old 02-01-2013 Thread Starter
Plimsoll Line
Standard load line marks
Load Line Mark and Lines and Timber Load Line Mark and Lines for power driven merchant vessels
Load Line Mark and Lines for commercial sailing vessels
The original "Plimsoll Mark" was a circle with a horizontal line through it to show the maximum draft of a ship. Additional marks have been added over the years, allowing for different water densities and expected sea conditions.
Letters may also appear to the sides of the mark indicating the classification society that has surveyed the vessel's load line. The initials used include AB for the American Bureau of Shipping, LR for Lloyd's Register, GL for Germanischer Lloyd, BV for Bureau Veritas, IR for the Indian Register of Shipping, RI for the Registro Italiano Navale, NK for Nippon Kaiji Kyokai, and NV for Det Norske Veritas. These letters should be approximately 115 millimetres in height and 75 millimetres in width.[6] The Load Line Length is referred to during and following load line calculations.
The letters on the Load line marks have the following meanings:
TF – Tropical Fresh Water
F – Fresh Water
T – Tropical Seawater
S – Summer Temperate Seawater
W – Winter Temperate Seawater
WNA – Winter North Atlantic
Fresh water is considered to have a density of 1000 kg/m³ and sea water 1025 kg/m³. Fresh water marks make allowance for the fact that the ship will float deeper in fresh water than salt water. A ship loaded to her Fresh Water mark in fresh water will float at her Summer Mark once she has passed into sea water. Similarly if loaded to her Tropical Fresh water mark she will float at her Tropical Mark once she passes in to sea water.
The Summer load line is the primary load line and it is from this mark that all other marks are derived. The position of the summer load line is calculated from the Load Line Rules and depends on many factors such as length of ship, type of ship, type and number of superstructures, amount of sheer, bow height and so on. The horizontal line through the circle of the Plimsoll mark is at the same level as the summer load line.
The Winter load line is one forty-eighth of the summer load draft below the summer load line.
The Tropical load line is one forty-eighth of the summer load draft above the summer load line.
The Fresh Water load line is an amount equal to \tfrac{\triangle}{40T} centimetres above the summer load line where \triangle is the displacement in metric tonnes at the summer load draft and T is the metric tonnes per centimetre immersion at that draft.
In any case where \triangle cannot be ascertained the fresh water load line is at the same level as the tropical load line.
The position of the Tropical Fresh load line relative to the tropical load line is found in the same way as the fresh water load line is to the summer load line.
The Winter North Atlantic load line is used by vessels not exceeding 100 metres in length when in certain areas of the North Atlantic Ocean during the winter period. When assigned it is 50 millimetres below the winter mark.[7]
Timber load line marks
Certain vessels are assigned Timber Freeboards but before these can be assigned certain additional conditions have to be met. One of these conditions is that the vessel must have a forecastle of at least 0.07 the length of the vessel and of not less than standard height, which is 1.8 metres for a vessel 75 metres or less in length and 2.3 metres for a vessel 125 metres or more in length with intermediate heights for intermediate lengths. A poop or raised quarter deck is also required if the length is less than 100 metres. The letter L prefixes the load line marks to indicate a timber load line.[7] Except for the Timber Winter North Atlantic freeboard the other freeboards are less than the standard freeboards. This allows these ships to carry additional timber as deck cargo, but with the facility to jettison this cargo.
The letters on the Timber Load line marks have the following meanings:
LTF – Timber Tropical Fresh Water
LF – Timber Fresh Water
LT – Timber Tropical Seawater
LS – Timber Summer Seawater
LW – Timber Winter Seawater
LWNA –Timber Winter North Atlantic
The Summer Timber load line is arrived at from the appropriate tables in the Load Line Rules.[8]
The Winter Timber load line is one thirty-sixth of the Summer Timber load draft below the Summer Timber load line.
The Tropical Timber load line is one forty-eighth of the Summer Timber load draft above the Summer timber load line.
The Timber Fresh and the Tropical Timber Fresh load lines are calculated in a similar way to the Fresh Water and Tropical Fresh water load lines except that the displacement used in the formula is that of the vessel at her Summer Timber load draft. If this cannot be ascertained then these marks will be one forty-eighth of the Timber Summer draft above the Timber Summer and Timber Tropical marks respectively.[7]
The Timber Winter North Atlantic load line is at the same level as the Winter North Atlantic load line
outbound and mad_machine like this.
aa3jy is offline
post #18 of 39 Old 02-01-2013
jackdale's Avatar
Originally Posted by aa3jy View Post
Bill Crealock designed pretty good boats.
jackdale is offline
post #19 of 39 Old 02-01-2013
SloopJonB's Avatar
Plimsoll Line
F – Fresh Water
And to think there are people who doubt that the sum total of human knowledge doubles every few years.
If anyone here doesn't know what the word Arcane means....now you do.
post #20 of 39 Old 02-01-2013
JimMcGee's Avatar
Jack, I won't argue that Cabo Rico makes solid boats but I can't imagine willingly setting out into the North Atlantic this time of year in a 36 footer no matter who designed or built her.
Didn't these guys ever hear of Dockwise...
95 Catalina 30 Island Time
“The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
Sailor rescued 160 miles off San Diego - San Jose Mercury News NewsReader News Feeds 0 11-06-2011 07:10 AM
French sailors rescued more than 1400 miles off coast - Boston Globe NewsReader News Feeds 0 09-09-2011 12:20 AM
Ike ravaged my marina! 1500 miles from shore! eMKay General Discussion (sailing related) 7 09-17-2008 02:46 PM
Couple rescued 230 miles off Cape Cod NewsReader Mass Bay Sailors 0 06-05-2007 11:15 PM
rescued from troubled boat 150 miles from Cape Hatteras - Virginian Pilot NewsReader News Feeds 0 11-08-2006 11:15 PM
