Life Span of a Boat - Page 10 - SailNet Community
 57Likes
post #91 of 103 Old 02-06-2013
Re: Life Span of a Boat
Rough guestimate:
that being something like 12m boat for about 50 square metres of fibreglass, at say 8mm thickness that would be roughly 100 gallons of rasin and 50 square metres of glass per layer. probably you get a better price when buying those amounts than when you buy 1/4th gallon
(so those 25k should be more than plenty enough actually)
Arjen is offline
post #92 of 103 Old 02-06-2013
Originally Posted by casey1999 View Post
Paulo,
Just curious would you know what a very rough material cost only (no labor) would be to build a hull for a boat using the molds you have pictured?
No, but I know that it depends on the technique. If vacuum infusion and epoxy resins are used you use a lot less material and that's why the boats made that way are lighter.
post #93 of 103 Old 02-06-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I think the hardest part of laying your own hull up would be knowing where to lay it on extra thick and which areas get more glass.
The good news is.. for more money, you could always go CF. even if you don't vacuum bag it, it would still be stronger than FG
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #94 of 103 Old 02-06-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I was thinking it might be easier to find a company that can sell only a bare hull/deck kit and finish it out. I haven't found many places that do hull's only.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #95 of 103 Old 02-06-2013
if you are going to do that.. why not just buy a really shabby boat that still has a decent hull/deck and strip and redo it how you want?
SloopJonB likes this.
Art Haberland
post #96 of 103 Old 02-07-2013
Senior Moment Member
SloopJonB's Avatar
Exactly - when I bought my complete & floating Columbia 43 (that "demonstrated a high degree of deferred maintenance") a VERY similar bare hull moulding (no deck) from a local manufacturer would have cost 4X as much. Also, that was 10 years ago, before the big drop in used boat prices.
Building from a bare hull is virtually certain to be the most expensive way you can acquire a boat and it will take a BIG chunk out of your life, frequently including your wife and family.
Nowadays it makes no sense - buy something close with good bones and customize it.
SloopJonB is online now
post #97 of 103 Old 02-07-2013
look at what Lackey did with an old Pearson Triton hull
The Daysailor | Building a Classic Daysailor
steve77 and casey1999 like this.
Art Haberland
post #98 of 103 Old 02-07-2013
Daniel - Norsea 27
I like looking at his main site at the project logs. I found his site from looking at certain models of boats and he just happened to restore one. Very good photo log of his work.
steve77, casey1999 and SloopJonB like this.
Daniel
1981 Nor'sea 27,
-Paul Carvel
post #99 of 103 Old 02-07-2013
he took away my fear of rotted decks. I can do glassfibre work.. I had no idea how easy it was to cut off the upper layer, chipout/cleanout the old balsa, and replace
Art Haberland
post #100 of 103 Old 02-07-2013
SloopJonB's Avatar
It's simple, not easy. I spent last summer doing patch repairs of the deck on my old 43'. Not much more complicated than making peanut butter sandwiches but I sweated off 30 unmissed Lbs doing it. As long as you are prepared to tackle a fairly big job there is nothing to fear about it.
I found stripping the bottom to the gelcoat, fairing and epoxy coating it to be as big a job and far harder due to having to work overhand.
Retraction of 520 Bridge draw span to halt traffic at 10:30 tonight - The Seattle Tim NewsReader News Feeds 0 05-08-2012 11:40 PM
Biloxi Bridge Span Collapses After Barge Strike Freesail99 General Discussion (sailing related) 3 03-21-2009 02:01 PM
Life span of a boat??????????? T37Chef Sailboat Design and Construction 62 06-13-2008 08:31 PM
Life Span of a Sail fjc1022@comcast.net General Discussion (sailing related) 5 06-15-2006 05:54 PM
