Life Span of a Boat - Page 11 - SailNet Community
 57Likes
post #101 of 103 Old 02-07-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Life Span of a Boat
working on the bottom, I might have to either farm out or do in small chunks. I have a problem with my right shoulder that makes it very sore to work overhead or if I pull my arm behind the centre line of my body.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #102 of 103 Old 02-07-2013
Those with a huge financial stake in constant design changes, and the building of new boats, are highly unlikely to support the concept of older boats still being good cruising boats.
Brent Swain is offline
post #103 of 103 Old 02-07-2013
Originally Posted by mad_machine View Post
I think the hardest part of laying your own hull up would be knowing where to lay it on extra thick and which areas get more glass.
The good news is.. for more money, you could always go CF. even if you don't vacuum bag it, it would still be stronger than FG
When a boat lays on her side on a beach , initially, the only two places which touch are the turn of the bilge and the bottom of the keel. You could build those areas up to several inches thick, using scraps, and it would drastically improve your chances of surviving a grounding. Until they broke up , the beach would never touch the rest of the hull. It would also have zero effect on performance.
That could easily be done to an older, single skin hull, not so easy on a cored hull.
Retraction of 520 Bridge draw span to halt traffic at 10:30 tonight - The Seattle Tim NewsReader News Feeds 0 05-09-2012 12:40 AM
Biloxi Bridge Span Collapses After Barge Strike Freesail99 General Discussion (sailing related) 3 03-21-2009 03:01 PM
Life span of a boat??????????? T37Chef Sailboat Design and Construction 62 06-13-2008 09:31 PM
Life Span of a Sail fjc1022@comcast.net General Discussion (sailing related) 5 06-15-2006 06:54 PM
