02-01-2013
formerly posting as eryka
Re: Power Outlet Sizzle - Help Please
I'm also going to join those who suspected you simply overloaded the circuit; although if that were the case, a properly-sized circuit breaker should have tripped - GFCI or no. If the circuit is 15 amp, that translates to roughly 1200 watts load, which means the space heater alone would be all you can have on it, once you added the iron, too much. If the circuit was 30 amp, then iron + heater should have been okay (assuming there was nothing else) and I'd suspect resistance from corrosion somewhere? Electrical isn't all that conceptually complicated, its just scary because when it goes wrong, it can go wrong BIG.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. still has some glitches to be worked out. Until then, I'm posting at: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ! And a new project: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
