Power Outlet Sizzle - Help Please - Page 7 - SailNet Community
 48Likes
post #61 of 61 Old 02-13-2013
JimMcGee's Avatar
Re: Power Outlet Sizzle - Help Please
Philzy, the thread has drifted a bit. Your problem is you need to bring in a competent professional.
Not all marine professionals are created equally. Drop an email to your surveyor. Ask about marine electricians he respects based on their work. Ask around the dock if anyone has used a local marine electrician.
Find someone good and trust their advice. As a live aboard this is your home. Boat fires, while rare are a very scary thing. If you see a boat burn you'll never forget how hot and how fast they burn. While they electrician is there ask questions about what you need to know about the system.
You also mentioned having smoke and CO2 dectors on board. Some, not all smoke detectors will last in a marine environment. You want to look for something labeled "for marine and RV use". A Home Depot CO2 dector is worthless on a boat. Marine dectors are calibrated differently. See this BoatUS arcticle.
When in doubt kill the main breaker, then kill the breaker on the dock. Do you have the correct fire extinguisher on board?
When you own a boat you're always learning something new. Best of luck, and please post an update to this thread to let everyone know how you made out.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
12v power outlet in cockpit dougklay Gear & Maintenance 22 09-11-2008 07:19 AM
Batteries Sizzle Like Alka-Seltzer theArchitect Gear & Maintenance 4 07-02-2007 08:42 AM
