double line vertical fairlead - Page 2 - SailNet Community
 5Likes
post #11 of 15 Old 02-02-2013 Thread Starter
Re: double line vertical fairlead
Well, I am going to defer to the wisdom of the more seasoned sailors here. Probably not a bad idea, considering when you add up the number of clutches and blocks and line and everything else I'd need it may not be that much cheaper than a furler anyway.
For now at least, I'll just look into a tiller stay.
Thanks guys.
blakeyoung is offline
post #12 of 15 Old 02-02-2013
Thanks guys.
If You feel safer having down hauls on your sails you could still do it.
You really don't need clutches and heavy blocks to rig a down haul.
These ropes is not loaded at all when you sail.
Not much force needed to haul down and you can most likely find a cleat to tie off to for the short time you need it.
Faster and dacap06 like this.
knuterikt is offline
post #13 of 15 Old 02-02-2013
bljones's Avatar
A sail downhaul is generally a light line weaving through the hanks or cars to the head of the sail- 1/16th" line will do fine. All you need are fairleads to lead it back to the cockpit and a couple of light cleats to secure and stow the lines.
Our genny is on a furler, but I like having a downhaul on the main because i can flake the main leech from the cockpit while the luff takes care of itself.
It's 5 o'clock somewhere:
bljones is offline
post #14 of 15 Old 02-02-2013
I saw a new Jeanneau at the the boat show with a pretty fat SS fairlead that you could run two lines thru. Looked like a pierce of pipe. I was thinking I could make something like that out of some SS pipe and a U bolt. Maybe you could stack to pieces of pile verticaly, with rounded corners and hold down with a U bolt.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #15 of 15 Old 02-03-2013
I sail single-handed quite a bit. Adding the Tiller Clutch was a big + for that. That said, I plan to run the topping lift line & cunningham line back to the cockpit. I only have room for two lines on each side of the deck between the hand rail and pop top.
H and E is offline
Double safety line upgrade question rbyham General Discussion (sailing related) 11 01-16-2013 07:22 PM
Converting to double-line reefing MarkSF Gear & Maintenance 21 07-09-2012 09:45 PM
double line reefing Barquito Gear & Maintenance 3 11-30-2010 03:46 PM
