Boat Ice - SailNet Community
 3Likes
post #1 of 18 Old 02-03-2013 Thread Starter
Boat Ice
I have never had a boat in water that froze in the winter and have questions.
Is it possible to be on a mooring or anchored out when ice starts forming or do you absolutely have to be at a pier to heat and/or bubble the water ? Is it possible to go out and just break the ice around the boat every day, or a few times a day, and manage it all through the winter ? Does that harm the boat ? Does having ice around the boat harm the boat, I assume it does or why would anybody bother to try to get rid of the ice in the first place, right ?
I understand that if your boat is in a marina and you have a constant supply of electricity you can bubble and/or heat the water but I am less interested in that, I really want to know what happens when that isn't possible.
Edit, also, I don't mean Boston during a cold snap with 1/4 inch of ice, I mean like Newfoundland in February with 6 inches of ice. I mean the kind of ice they probably get in places like Alaska.
What are you pretending not to know ?
Please support my
wind_magic is offline
post #2 of 18 Old 02-03-2013
美国华人, 帆船 教授及输送
Re: Boat Ice
Just another good reason to list your location in your profile so other can answer your question accordingly. In Chesapeake bay, a few inches of ice won't hurt, but in the Great White north, the frozen solid ice that can support a semi is another story. It will crush your boat into pieces.
I assume that you did not pull your boat out and there are plenty of boats around your area are still in the water. I guess the good news is you should be OK.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #3 of 18 Old 02-03-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Boat Ice
I would think in a boat with slack bilges, the boat would start to ride up as the ice tried to crush it.. on something with hard chines, your guess is as good as mine.
The chesapeake has frozen sold before. Not enough to drive a semi over, but enough that it was solid ice from one side of the bay bridge to the other.. I don;t know how thick it would have to be to do that
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #4 of 18 Old 02-03-2013 Thread Starter
Re: Boat Ice
Thank you for the response, Rock.
Of course I'm not talking about where I am or I'd already know.
I'm talking about places far north that I have no experience with.
Is that what happens, I wonder, does the boat eventually get lifted out of the ice and tilt over to one side ? That would be better than having it crushed.
Please support my
post #5 of 18 Old 02-03-2013
steve77's Avatar
Re: Boat Ice
You might find this interesting, a boat that was specifically designed not to be crushed by ice:
BLDGBLOG: The Architecture of Polar Ice Floes
Do a google image search for "boat frozen in ice" and you'll see some interesting things.
Like this:
steve77 is offline
post #6 of 18 Old 02-03-2013
KIVALO's Avatar
Dock
Re: Boat Ice
Kinda like this aesomeness??!!
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
post #7 of 18 Old 02-03-2013
Boatswain
IronSpinnaker's Avatar
Re: Boat Ice
My Grandfather was a Commercial Fisherman and owned his boats. He always left them in all year around. He tells a story about a boat that sunk one winter back in the late 60s early 70s. It was an abnormally cold winter and the boat kept freezing in so every morning he would go down and break the ice from around it. He said one morning he arrived to see the boat sinking, water poring in over the stern. He said the ice froze in around it over night and when the tide went out the ice broke, but when the tide came back in the ice had jammed on it's self and prevented the boat from floating back up with the tide... flooded the boat.
wind_magic and oysterman23 like this.
Signature
IronSpinnaker is offline
post #8 of 18 Old 02-03-2013
Tim R.'s Avatar
Re: Boat Ice
You could break the ice away from the water immediately surrounding the boat but how will your boat swing?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #9 of 18 Old 02-03-2013
CrazyRu's Avatar
Re: Boat Ice
You will need to build a compressible cushion around the boat. Car tires, hey, lots of it.
The problem is that an ice is not solid. It moves. It can compress a boat. Mass of the ice is huge, think about fields crashing against each other, tectonic plates. I know guys on steel boats wintering in Baltic, it is an art...
Also there is no mooring designed to withstand a square mile of ice moving with a boat attached.
CR
s/v NEMO - Freedom 28 Cat Ketch, centerboard
CrazyRu is offline
post #10 of 18 Old 02-03-2013
Re: Boat Ice
An ice breaker does not cut through the ice persey.. it is designed to ride up atop and use the weight of the ship to break and crush it down. It is also designed with round bilges so that if it gets stuck, it does not get crushed, it simply rides up.
Such as this Icebreaker here.
As noted in an above post.. most ships that get sunk in ice do so because they get trapped and pulled/pushed under by the movements of the ice. In the artic, this can happen because of winds and tides hundreds of miles away.. but at the dock, due to the ice keeping your boat from rising with the tide.
As to the above picture of an ice covered boat.. Ice will make your vessel topheavy.. not too big a deal with a sailboat.. but enough ice will capsize a powerboat and even a large ship if allowed to build up on the decks and superstructure
Art Haberland
WANTED: BASIC BOAT BBQ. CHARCOAL IS OKAY, BEATUP IS OKAY, ANY BOAT BBQ - $25 seattle stephenronning Gear & Maintenance 2 03-30-2009 09:21 AM
Coast Guard finds missing boat, still searching for other boat - FayObserver.com NewsReader News Feeds 0 05-11-2007 11:15 PM
Coast Guard finds missing boat, still searching for other boat - Access North Georgia NewsReader News Feeds 0 05-11-2007 10:15 PM
Coast Guard Finds Missing Boat, Still Searching For Other Boat - WSOCtv.com NewsReader News Feeds 0 05-11-2007 04:15 PM
Coast Guard finds missing boat, still searching for other boat - Myrtle Beach Sun News NewsReader News Feeds 0 05-11-2007 08:15 AM
