van de stadt - SailNet Community
post #1 of 15 Old 02-06-2013 Thread Starter
van de stadt
I am bying a van de stadt excalibure steel cutter 30 1984 does any one know this type of boat. The motor is new and the hull been re painted. I want to take it offshore sailing.
rigalio is offline
post #2 of 15 Old 02-06-2013
Re: van de stadt
I don't know the Excalibur 30 but way back when I worked in a boatyard in Marblehead, we would occasionally haul and paint Van de Stadts that had made the Atlantic crossing. In general, a good reputation and should be offshore-worthy.
nolatom is offline
post #3 of 15 Old 02-06-2013
bljones's Avatar
Re: van de stadt
You must have bought the boat that was for sale in kingston. Apparently it was built by Holland boats in 1976, from a Vandestadt plan. It looks like it is actually one of van de stadt's Wibo series designs, that has been modified.
Van de Stadt Design - Wibo 930
Heres a full (and very impressive) list of VDS designs:
Van de Stadt Design
Holland Boats built a few of these steel designs, and seemed to have called them excaliburs, although VdS doesn't list any exaclibur in the design catalog except the fiberglass excalibur 36.
It's 5 o'clock somewhere:
bljones is offline
post #4 of 15 Old 02-06-2013
Re: van de stadt
Make sure you get a good surveyor to go over the boat with you.
Catalina 34
chuck53 is offline
post #5 of 15 Old 02-06-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: van de stadt
Ah interesting .... from Jonesy's pic that model is obviously a predecessor of the later VDS 34 and 40 (Caribbean) two of Van de Stadt's most respected designs.
Our previous boat was a VDS34 and she was a bloody marvelous boat. We loved her.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #6 of 15 Old 02-07-2013 Thread Starter
Re: van de stadt
Yes it is the one in Kingston and now I did purchase the boat. There is no frigo on board it is an ice box, That's I will have to install a freezer or a littel fridge I am thinking more fore a freezer cause it can make ice fore the ice box and keep some frozen food.
rigalio is offline
post #7 of 15 Old 02-07-2013
billyruffn's Avatar
Re: van de stadt
I have a VDS designed boat and they are well known for strong, comfortable passagemakers. Be aware that VDS is the designer and not the builder. VDS is a very well known Dutch naval architect. Owners buy their designs and have boats built from them. If the boat was built in Holland chances are it was done in a yard with experience in steel boat construction. It would be worth your while to determine where and by whom the boat was built.
I would recommend you find a surveyor who knows steel boats -- most likely to be someone who surveys commercial fishing boats and the like rather than one who specializes in yachts. Be sure you have your surveyor carefully inspect the interior of the boat. Steel boats usually rust from the inside out. Careful maintenance of the interior surfaces is key to the long life of a steel hull. If the boat was professionally built you're much better off than if it was home-built from the VDS design. Amateur builders usually aren't as experienced in how the structure goes together. They may be professional welders, but there's a lot more to it than welding things together. And then there's the painting -- again something for professionals to do because tehy have all the right gear for it. For example: I've had problems with rust in the limber holes, primarily because it was difficult to spray paint all the surfaces. I've been told by an experienced surveyor that the builder knew what he was doing, but the painters probably created the problem. Had the painters hand painted the limber holes I'm sure the problem would not be as significant. Another little detail I just discovered this time the builder's fault -- the builder of my boat used threaded steel pipe welded to the hull (in and out) as the base for the seacocks, which are SS ball valves. I recently had to replace one of these seacocks because of the need for more raw water for a new engine. When we cut the steel pipe flush with the inside of the hull we discovered that we had lost approx 50% of the pipe wall to corrosion over the last 17 years. As a result I'm replacing many of the thru-hulls with Marlon fittings as a precaution. It's details like this that can make all the difference in how long the boat will last.
Again, the designer has little or no impact on things like this -- they may specify that things be done a certain way, but there is no guarantee that their spec was followed by the builder. Again, professional builders experienced in steel construction will probably be much more likely to follow specs than an amateur builder (who after all is building the boat because they don't have enough money to have it built professionally -- and hence, is much more likely to cut corners and to make mistakes because as they say, "he don't know what he don't know".) You need to know both the reputation of the designer (in this instance very good) AND the reputation of the builder.
Exterior maintenance is easier in many respects, but still requires attention. I"ve said in other posts that steel boats are a labor of love. If you keep after the rust they will last a very long time. If you don't you'll have big problems.
You should inquire about the paint schedule they used in repainting the boat. New paint can cover a lot of rust and you won't see it for a year or more. If the boat was well preped (all rust ground out, treated, primed 2X, filled and faired, primed again) and then and only then, finish painted chances are you will get 7-10 years out of the paint job. Don't be fooled it they say it was Awlgrip-ed. Awlgrip and Awlcraft (which I use) are great paint systems, but they will not last unless the undercoating was done correctly.
Good luck in the purchase. I love my steel boat (even more after hitting a few hard things through the years), but I've seen some real steel hulled disasters. New paint and new engine is nice, but it's only a small part of the equation.
PS -- Just read your last post and looks like tha advice above is a tad late. Re the frig/freezer -- make sure you touch base with Cleave at SeaFrost in NH. He's a good guy, really knows he business and builds some very good systems -- I have two aboard.
billyruffn is offline
post #8 of 15 Old 02-09-2013 Thread Starter
Re: van de stadt
My trade is in refregeration and I know verry well about fridgs and I can built it too
rigalio is offline
post #9 of 15 Old 02-09-2013
One of None
deniseO30's Avatar
Re: van de stadt
HVAC here too rigalio! 12 volt refrigeration.... is a pain in the A....
My last project!
deniseO30 is offline
post #10 of 15 Old 02-10-2013 Thread Starter
Re: van de stadt
I did check it ot a bit and gonna figure it ot in time
rigalio is offline
Van De Stadt. marty1916 Boat Review and Purchase Forum 3 05-31-2009 05:49 PM
Van de Stadt Pionier 9 K45 Boat Review and Purchase Forum 1 05-11-2008 10:02 PM
Van De Stadt sthundley General Discussion (sailing related) 9 05-16-2007 12:02 PM
Van d' Stadt- How to check which paint to use vascotx Gear & Maintenance 0 09-18-2006 07:02 PM
