Oh what to do? boat on rocks/reef/sand/mud - Page 4 - SailNet Community
 11Likes
post #31 of 36 Old 02-07-2013
Senior Moment Member
SloopJonB's Avatar
Re: Oh what to do? boat on rocks/reef/sand/mud
Originally Posted by jackdale View Post
In my first sailing course the following advise was offered:
When you run aground on Spanish Banks, the first thing you should do is take the largest towel that you have on board and use it to cover your transom.
That demonstrates a guilty conscience. Get off the boat with a brush and start scrubbing the bottom - then it looks intentional and VERY salty - you are "careening" just like Nelson.
P.S. after doing most of my sailing around here, where Spanish Bank is just about the only non-rock bottom anywhere, I have to say that running up on sand or mud hardly qualifies as "running aground" - it's just "rubbing" bottom. If you don't have to do some work on your keel at the next haulout, it doesn't count as a REAL grounding.
SloopJonB is offline
post #32 of 36 Old 02-07-2013
This method can easily drive you further aground if not careful.
Very True! It all depends on the wind direction and knowing the charted depths immediately surrounding the boat. If everything 'clicks' the solution is to heel as much as possible and try to make a 180 turn. You do need some moderate wind (from the right direction) to make it work. In another instance, I've used the heeling approach while motoring a 5 foot draft boat through 4.5 foot depths in and out of the approach to Spring Cove Marina in Rock Hall. Looks a little dare-devilish negotiating that channel with the full jib unfurled.
Seaduction is offline
post #33 of 36 Old 02-10-2013
If you are the US Navy just tell the authorities to call the embassy ...then wait for salvage operations to cut your boat into tiny pieces......Oh, of course blame the charts....because your seamanship is beyond reproach.
AKscooter is offline
post #34 of 36 Old 02-10-2013
TQA
Bombay Explorer 44
TQA's Avatar
OK here is my list. It assumes that I am in passage making mode.
Drop dink and fit OB aprox 200lbs.
Sound the area from dink using oar which is marked with the boat's draft
Layout kedge in direction of deep water and tension using cockpit winches.
Drop both anchors and all chain from bow. 2 x 50lb anchors and 400ft chain 770lbs.
Empty water tanks 150 galls 1200lbs
If it has not refloated the boat would be heeled over using a masthead halyard. [ I would use this strategy earlier if help was on scene or I had crew onboard. ]
The strategy of heeling the boat using a masthead halyard is the key to getting most boats off in my experience. Not bilge keelers or wings though !
In 10 years of liveaboard cruising I have helped in a number of rescues. A call on the VHF often produces a dinghy squadron.
hallucination likes this.
TQA is offline
post #35 of 36 Old 02-10-2013
Closet Powerboater
MedSailor's Avatar
+1. I tried a bunch of stuff and this strategy really works! I also like the idea of dropping the main anchor and chain to reduce weight.
I keep a leadline handy for sounding from the dinghy. I use it all the time.
MedSailor
MedSailor is offline
post #36 of 36 Old 02-10-2013
TQA
Bombay Explorer 44
TQA's Avatar
On a related topic does anyone else still have a
OCAFCRATS
T shirt.
Brownie points if you know what it stands for. Clue it relates to the Bahamas.
TQA is offline
Boat on Rocks, One Death, South of Comox/Courtenay jackdale Pacific Northwest & Alaska 10 01-09-2013 12:34 PM
love on the rocks(I mean my boat) safetyteach SailNet FAQ 3 10-08-2011 10:26 AM
Club sailing team rocks the boat NewsReader News Feeds 0 09-21-2011 03:30 AM
Stranded boat towed off rocks - WTNH NewsReader News Feeds 0 08-15-2006 07:15 PM
Two rescued after boat gets stuck on rocks - WTNH NewsReader News Feeds 0 08-15-2006 08:20 AM
