Cushion Cleaning - SailNet Community
post #1 of 3 Old 02-07-2013 Thread Starter
Blue Horizons
Harborless's Avatar
Cushion Cleaning
I have foam cushion inserts in fabric. They are pretty thick. I want to clean them. Last times I did them I stepped all over them like grapes in a bucket while a hose ran on them.... this was not a geat result.
This time I was thinking I could just rent a steam vac and use that? I only worry the steam wont properly clean sense the foam is neoprene I believe or by any means is not conducive to water. Will steam vac cleaning work?
Is there an industrial dry cleaner in Jacksonville I can drop them off at?
What do you people do? The cushions do not have zippers so I cannot just take them out and clean each individual. ,
Harborless is offline
post #2 of 3 Old 02-07-2013
guitarguy56's Avatar
Re: Cushion Cleaning
Rather than writing up the article again: cushion cleaning
Unfortunately you might have to remove the foam out of the cushion covers to clean... are you good at hand stitching???
guitarguy56 is offline
post #3 of 3 Old 02-08-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
good time to add some zippers
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
cal 29 cushion (how to get them off) jlberkeley Gear & Maintenance 0 07-12-2012 11:19 PM
Boat Cushion mm2187 General Discussion (sailing related) 7 05-19-2012 07:22 PM
Cushion Covers simple72 Gear & Maintenance 3 11-09-2006 08:27 AM
Interior cushion cleaning duffer1960 General Discussion (sailing related) 6 06-27-2005 05:34 AM
Interior cushion cleaning duffer1960 Gear & Maintenance 3 04-17-2005 08:41 AM
