Like Tree2Likes
  #11
Old 02-11-2013
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Re: ridding bilge of sewage odor
...and damage any rubber...
Rubber gloves, Clorox Cleanup and paper towels work well.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #12
Old 02-11-2013
RichH's Avatar
RichH will become famous soon enough
Ditto Raritan KO ... an enzyme based chemical system ... and alternated with 'heavily CAUSTIC' soaps/detergents .... ie. Lye Soap from an agricultural supply shop - Agway, etc.
Both the enzyme based and the caustic based need SOAK TIME to work.
When finished with the 'caustic', add plenty of vinegar, then lots of water, etc. to help neutralize and dilute before pumping out.
Tags
sewage odor
You may post attachments
You may edit your posts
Sewage Line weephee Gear & Maintenance 2 04-08-2012 07:16 AM
Sewage Hose or PVC Pipe ? Cotemar Gear & Maintenance 17 12-27-2011 10:04 PM
Halyards, Hand bilge pump, and sewage tank ukrsindicat Gear & Maintenance 3 08-09-2010 07:58 PM
sewage pump-out question.. groundhog Gear & Maintenance 6 05-30-2007 03:02 PM
SEO by vBSEO 3.6.1
