Headsail only in heavy weather? - SailNet Community
 5Likes
post #1 of 16 Old 02-10-2013 Thread Starter
I have read that having at least some sails up during a gale not only allows your boat to make headway but adds to its stability. Does the membership agree?
In the Annapolis Book it basically states that unless in relatively small waves, sailing under reefed main alone is preferable to sailing under storm jib alone. The reason they give is that the main supports and stabilizes the mast and prevents "mast pumping". Do you guys generally agree with this?
I would imagine that I would only contemplate going under storm jib alone if I were going down wind. I can't imagine that it would make being on a close haul or close reach easy due to the lee helm. But what about down wind reaches and runs?.... I could imagine doing that under jib alone and a number of contributors here have advocated that during heavy weather. Is the risk of mast pumping that serious? Wouldn't a tensioned headsail halyard stabilize the mast as well?
matthewwhill is offline
post #2 of 16 Old 02-11-2013
MarkofSeaLife's Avatar
Dock
Re: Headsail only in heavy weather?
I wouldnt worry about mast pumping.
Downwind a small amouunt of genoa rolled out is good. I dont advocate storm jobs any more.... most boats have furling genoas and no one is going to whip that off in 40+ knots to put up a storm job.... unless they are crackers, of course.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #3 of 16 Old 02-11-2013
SchockT's Avatar
Or they just know what they are doing! Of course it also depends on whether they are short handed or fully crewed.
How a boat handles a headsail without a main really depends on the boat, type of rig etc. My boat seems pretty happy with just a jib when it is blowing. When the main is down I connect the main halyard to the end of the boom and pull the sheet on, and I have a baby stay to control pumping.
Having said that, I have yet to try it in extreme conditions. 25-30kts with a #3 is the most I have tried.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #4 of 16 Old 02-11-2013
aeventyr60's Avatar
My cutter rigged boat does well with a hanked on staysail in 40+ knots downwind....Storm jib for anything more serious...like 3 days hove to in the Southern Ocean.
BluemanSailor likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #5 of 16 Old 02-11-2013
Of course this is the reason for the Gale Sail design, the storm jib that goes over the top of a furlled genoa.
Never the less, seems it's not really needed that much unless the boat cannot manage to unfurl a tiny patch, like 25%, without risk of getting it all out.
G.J.
SailingJackson is offline
post #6 of 16 Old 02-11-2013
Old enough to know better
It really depends on the boat, some will not balance at all with just a mainsail, and other boats are the other way around. So this is one of the things that you must know your boat and it's characteristics. This is really an area that trial and error comes in handy, just do it in slightly less than force 10 conditions! Oh and you expect that people here will agree on anything?
I will take most any job if it pays enough! A storm sail would give a lot better shape, but yes unless you have the ATN type gale sail, then it is unlikely that you would put one up.
miatapaul is offline
post #7 of 16 Old 02-11-2013
Broad Reachin'
kwaltersmi's Avatar
I might look into a storm trysail if I were planning to do a lot of heavy weather sailing. My main has two reefs, but even the smallest reef can feel like too much canvas in a big blow. I also don't like the awkward strains that are put on my partially furled headsail and rigging when it's really blowing. Bottom line for me is I need more practice in heavy weather to figure out what works best and what I'm comfortable with.
Catalina 34
kwaltersmi is offline
post #8 of 16 Old 02-11-2013
Dock
OK, then go find a windy day, leave the crew at home and try to put your gale sail up by yourself.
Now contemplate doinig it at 40 knots.
Sea Life
post #9 of 16 Old 02-11-2013
RichH's Avatar
Thats OK in your true cutter rig because the design overall CE is within that staysail; plus, your mast is at about ~50% LOA .... not the typical sloop with its combined CE behind the mast at ~30% LOA.
aeventyr60 and aeventyr60 like this.
RichH is offline
post #10 of 16 Old 02-11-2013
RichH's Avatar
You will or should if that mast is now harmonically moving back and forth to the extent that your stays/shrouds are momentarily (instantaneously impacting) exceeding the material strength limits of the wire ... and your chainplates are 'old' and full of 'accumulated fatigue'.
Most chainplate systems are grossly under-designed for fatigue failure ... right out of the boat builders shop. With the common stainless steels you only get about 1 million load cycles (about 1 circumnavigation) above 30% stress ... then the plates, etc. are usually very prone to fail, suddenly and without much warning.
jrd22 and casey1999 like this.
RichH is offline
heavy weather sailing nolasailor Learning to Sail 4 10-10-2011 10:08 AM
headsail terminology questions (heavy/light) richrand Gear & Maintenance 25 04-16-2009 08:03 AM
Heavy weather furling? MedSailor Gear & Maintenance 17 04-18-2008 10:11 PM
Avoiding Heavy Weather Michael Carr Seamanship Articles 0 10-28-2004 08:00 PM
heavy weather???? nauticalrich Seamanship & Navigation 12 05-08-2002 05:22 PM
