Electric hybrid Inboard Vs Diesel - Page 2 - SailNet Community
 2Likes
post #11 of 26 Old 02-14-2013 Thread Starter
Re: Electric hybrid Inboard Vs Diesel
Originally Posted by jppp View Post
Have to make sure all gaskets and hoses are synthetic as the bio will dissolve them.
I have to make sure they are synthetic or are not synthetic and is that on the tank etc or the whole motor?
SirRedemption is offline
post #12 of 26 Old 02-15-2013
chucklesR's Avatar
A Honda 2kw will actually probably not give you 3kts or so.
It's rated for 1.3kw continuous, which is in the range of only 1 hp, and there is no such thing as a free lunch.
Unfortunately hybrid just isn't ready for long term cruising yet, and simply isn't cost effective (certainly not on a 1969 boat).
chucklesR is offline
post #13 of 26 Old 02-15-2013
I'm basing that estimate off what people are seeing in the field: THE BIANKA LOG BLOG
A 28ft boat would probably re-power along the lines of a 6kw electric drive. 1.3kw continuous will drive a 28ft boat faster than you'd think. Power requirements for each knot of speed go up exponentially. It actually takes very little power to scoot along at 2 or 3 knots.
LauderBoy is offline
post #14 of 26 Old 02-15-2013
chucklesR's Avatar
Prop's that are designed for the low speed high torque you can get from electric are more efficient, that helps.
I have a 44 pound thrust trolling motor that I used last summer on my friends Coronado 25. It used 40 ah at full speed, 12v = 480w
Full speed was a GPS measured 2.3kts on flat water, reduced to 1kt away from the pier.
Hey, it got us sailing but that's about it.
The problem here is that in order to recharge that battery and keep up he would have needed a 40 amp charger - I've got a 38 footer with a 20amp, think many 25's have a 40?
post #15 of 26 Old 02-15-2013
Well a 40 amp charger, especially one that likes the charge the gennie puts out, would need to be installed. As would a 48v(or whatever) battery system. And a way to charge both the 48v/12v system on the boat. And battery monitors. And you need to consider the safety of a 2kw gas generator that'll be spewing out exhaust. And then live with the power constants of the system. If it was perfect we'd all be using it.
But I also notice people tend to give petrol systems a pass on a lot of their flaws, because they're used to them. Filtering fuel, polishing fuel, getting "bad" fuel, constant maintenance, holes in your boat for water in/out, zincs to prevent heat exchanger rust, rough seas causing gunk in the tank to free up and jam the fuel system and killing the engine(probably when you need it most), little rubber impellers that fail all the time, water intake clogging up, busted ring seals causing blue smoke out the exhaust, the noise, the smell, crap torque on the low end, no regeneration under sail, you can't lift the engine out by hand, etc etc.
If someone was coming from the electric side and was used to the aux engine range limits, they'd probably think of the idea of re-powering with diesel as laughable.
post #16 of 26 Old 02-15-2013
Another thing to remember is battery storage. The Columbia 28 does not have a lot of battery storage space. Where are you going to put the larger, heavier batteries? Where are you putting the generator? What will all this additional weight do to the sailing abilities of the boat?
Instead of a complete redesign, just do an overhaul of the A-4 or install a small diesel.
s/v Odyssey
Catalina 30
glassdad is offline
post #17 of 26 Old 02-15-2013
tommays's Avatar
I have a fleet of state of the art 48 volt (which means the batteries are inverted to produce AC for the drive motor) standup reach trucks and if you think that’s NOT the most complex thing on the planet I do not know what to say ?
Other than that are propane units have far lower care requirements needs and you have not spent much time keeping doing the care required to keep heavily used battery’s alive
My A4 is a good bit simpler than my riding lawn mower and if you can’t keep one running your surly going to have difficulty keeping up with a complex electric system in saltwater
End of ramble
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #18 of 26 Old 02-15-2013
@glassdad The weight you get from the engine plus fuel tank is what's replaced by the electric engine and batteries. A Thoosa 9000 weighs about 45lbs, so it's really just battery weight.
@tommays The system is far less complex than you're making it out to be. After 5 years of use, here's the first real maintenance that one owner has had to do: THE BIANKA LOG BLOG: EASY ELECTRIC BOAT MAINTENANCE PART ONE: REMOVING THE MOTOR
From his blog, his Honda generator has been more maintenance than anything else.
post #19 of 26 Old 02-15-2013
chucklesR's Avatar
Lauderboy,
Not to shoot the messenger, but I call foul.
The Thoosa 9000 is 7,790 bucks
The 4 8d Agm's he has to power it (for 48v A 200 ah) are 500 bucks each.
That's 10 grand with DIY installation.
That doesn't even include the charging system, another grand for the Honda.
All that for 4 hours of motor time?
No comparison, and doesn't meet the needs of a cruiser.
It's not even cost effective to operate, he'll need to replace that 2000 dollar bank long before I've spent 2k in fuel.
Capnblu likes this.
post #20 of 26 Old 02-15-2013
Initial cost is absolutely higher. Especially if you can re-power with a rebuilt Yanmar and run a DIY install on that. On the battery costs, you're leaving out diesel maintenance. It's not just fuel expense there. Diesel engine service 3 years back was $450 for me and my last one was a nice $700 day job.
As for "needs of a cruiser", you can't speak for all cruisers in that. It's obviously meeting the needs of the owner of Bianka.
Diesel-electric hybrid deckofficer Gear & Maintenance 77 03-14-2012 11:16 AM
Catalina 25 with a inboard diesel H and E General Discussion (sailing related) 3 09-20-2011 10:01 AM
Budget Electric inboard bmacfarquhar Gear & Maintenance 16 02-23-2010 07:54 PM
Diesel/Electric Hybrid ronspiker Gear & Maintenance 8 07-09-2008 01:17 PM
hybrid electric bluetommy77 Gear & Maintenance 11 10-20-2007 01:35 PM
