Where to do USCG licensing physical/drug test in Northern California? - SailNet Community
post #1 of 8 Old 02-14-2013 Thread Starter
dbrimm's Avatar
Title pretty much says it all, it's time for me to renew my USCG captains license and I need the special physical they require and the appropriate drug test as well.
So, has anyone actually done either or both of these anywhere in Northern California (say, the Bay Area or north) in the past year or so, submitted them and had them accepted by the CG?
Last time I did mine it was in SoCal and I don't know where to go up here.
Thanks in advance!
Dave
dbrimm is offline
post #2 of 8 Old 02-14-2013
Re: Where to do USCG licensing physical/drug test in Northern California?
Your licensed physician/P.A. should be able sign off the physical requirement.
Drug Test Information - USCG National Maritime Center
aa3jy is offline
post #3 of 8 Old 02-14-2013
You could also do a search for offices that issue D.O.T. Medical Certificates for CDL's in your area.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #4 of 8 Old 02-14-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
For what it is worth.. friend of mine was forcibly retired out of the Army Corps of Engineers after failing his physical for the CG.. which is a good thing. According to his doctor, he was about 3 to 4 months from a widow maker heartattack. He had no idea that his heart was in such bad shape until he went to renew his license and failed the physical
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 8 Old 02-14-2013
A DOT physical is how I discovered having high blood pressure...
misfits is offline
post #6 of 8 Old 02-14-2013
Try contacting a maritime school in the area. They should be able to give you a name of a doctor that is familiar with the CG paperwork. I've heard docs that have not done it before often screw it up.
SteveInMD is offline
post #7 of 8 Old 02-14-2013 Thread Starter
dbrimm's Avatar
Thanks for the responses guys, much appreciated.
@ SteveInMD - that would be great if you hear back Steve. That's exactly the problem I've run into, Dr's that are unfamiliar (or don't have exactly the right eye testing kit) and my packet gets bounced back by the CG. Gets annoying and expensive to have to repeat and try again.
dbrimm is offline
post #8 of 8 Old 02-14-2013
Free advise is worth what it costs, etc, but . . . A prior poster suggested contacting at DOT examiner. Examiners for flight physicals also do DOT exams (or at least they used to)
You might consider asking the local flight schools/airports who the flight physical examiners are, and asking if they also do CG exams. Some aviation examiners have a time and place where they exam anyone who shows up, no appointment needed. Such examiners would probably be willing to gossip with you.
Varies with the thoroughness of the exam, but routine exams on healthy subjects find about 15% have previously unknown illnesses. Half of those are treatable. FWIW
dongreerps is offline
PT Plans Sailboat Adventure to Benefit Foundation for Physical Therapy - Physical The NewsReader News Feeds 0 06-29-2012 10:20 PM
Greetings from Northern California deckofficer Introduce Yourself 14 02-19-2012 10:32 PM
USCG Licensing online Duck401k General Discussion (sailing related) 6 01-19-2009 06:05 PM
Hello from northern California Skimmer Introduce Yourself 0 07-31-2008 01:14 PM
