What is so bad about a Porta Potti? - Page 2 - SailNet Community
 1Likes
post #11 of 35 Old 02-16-2013
Large Member
Re: What is so bad about a Porta Potti?
Personally, I find the Pett bag system better than pp's. Works well for #2 also.
The dumping and cleaning of pp's are disgusting IMHO. True, if #1 it's not so bad but I like to just walk down the pier and drop the bag in the closest trash can/dumpster.
Since there are very few pump outs in these parts and most trailer sailers find it hard to install a real toilet... we find the bag system the best alternative.
mdbee is offline
post #12 of 35 Old 02-17-2013
Has anyone tried the Round Hassock Toilet?
sony2000 is offline
post #13 of 35 Old 02-17-2013
Siamese's Avatar
We use our Catalina 309 for daysailing and the occasional weekend or 2 week trip. We took out the smelly, troublesome head that came with the boat and put in a porta potti. For the way we use our boat, the porta is superior to a head and holding tank in just about every way.
It's important that you use the chemicals in it, and empty it at least every two weeks. Smell is not an issue. Less than with the stock system.
Emptying is very easy with our Thetford brand porta. Just dump the lower portion of the porta into a toilet. There's a large pipe that swings out for emptying, making it clean and easy.
Anyone using the stock toilet on a 309 (a typical marine toilet), is going to be very sad when they or a guest takes a substantial dump. Hey, captain, have fun cleaning that up. The porta will take anything you throw at it.
Worst case scenario is that you have to dump it overboard when nobody's around. I hear fish bypass the porta and poop directly into the environment. Imagine that
Siamese is offline
post #14 of 35 Old 02-17-2013
Learning a bit every day
FinallySailing's Avatar
We have a Dometic PP on ours. With two adults and two children more than adequate for day and weekend sailing. No stink as I always use the chemicals with it (aqua kem green) - I actually quite like the smell of it. We use special toilet paper that will dissolve quickly in the holding tank. The tank is easily carried to the next public toilet and emptied out there. I find that cleaning is nowhere worse than that of a normal toilet at home.
FinallySailing is offline
post #15 of 35 Old 02-17-2013
Irunbird's Avatar
I second the Thetford, and that makes one less reason my wife has to say "no" to an extended day or two on the boat. We also will frequently have female crew and it's a whole lot better for them to use it than ye ol' bucket... that's a guy/racer thing.
Irunbird is offline
post #16 of 35 Old 02-17-2013
rh, maybe she's afraid you'll do a drug test. (G)
I suppose a bedpan would really traumatize her. Do you have a "real" seat on your bucket, or just a real bucket? Maybe something with a seat would pacify her? They do make snap-on lids for plain buckets, that have a real seat. Not very expensive, adds a little civilization.
Or you can line it with a plastic bag, throw in a handful of kitty litter (half to what you think you'll need) and absorb the pee. Then just pick it up and throw it out ashore, no washing needing, no pee to splash around.
Maybe if you just promise her that you won't do the drug test. (G)
hellosailor is offline
post #17 of 35 Old 02-17-2013
It really helps if the Porta-Potti can be used behind a door or curtain. Perhaps the girls shy away from using it in the open saloon.
Seaduction is offline
post #18 of 35 Old 02-17-2013
Canuck Sailor
Send a message via Skype™ to canucksailorguy
I remember one day after a lovely sail, sitting dockside, having a cold libation, waiting for the sunset. Then - five guys came down the dock, carrying their little briefcases full of - well, full of whatever they were full of.
Ruined the entire evening.
Sorry, but if you have to carry your bodily fluids about, carry them inside your body, not in a translucent 'briefcase' for all the world to see. A properly functioning head isn't all that big a deal to install and it simply reeks of civilization - and nothing else if you do the job right.
Cuba - Forbidden Paradise
canucksailorguy is offline
post #19 of 35 Old 02-17-2013
We have a PP that is plumbed for pump out. Only got the boat last fall and will be launching it in May so stay tuned for PP updates.
i_amcdn is offline
post #20 of 35 Old 02-18-2013
We use a PP in our 25 footer. Mostly we go over the weekend. Two days is fine for 2 or 3 of us. Some trips are longer. It's a bit of a pain, but we'll take it out for 6 days at a time. We dump at a marina and once or twice, made sure we were out far enough and over the side. We use the biodegradable, non-toxic chemicals. Paper is not an issue. The effluence is a choco-slurry . . . no solids. Gross but good to know.
So . . . use the PP. Not a big deal and there when you need it.
DonScribner is offline
Chaninging from Porta-Potti to pump out cb32863 Gear & Maintenance 13 06-01-2012 02:58 AM
PORTA POTTI - A 'no no' or 'okay' for cruising? SailMonkey General Discussion (sailing related) 44 05-31-2012 11:23 AM
Porta Bote lancelot9898 Gear & Maintenance 8 03-03-2009 02:42 AM
Block Island, RI & a porta potti kwf05001 Cruising & Liveaboard Forum 11 04-24-2008 02:17 PM
porta potties? jbarros Gear & Maintenance 6 01-02-2003 06:41 AM
