Like Tree1Likes
  #21
Old 02-18-2013
Seaduction's Avatar
(retired)
Seaduction is on a distinguished road
Re: What is so bad about a Porta Potti?
OK boys and girls... enough of this potty talk!
  #22
Old 02-19-2013
ABH3 Boyer is on a distinguished road
When I remodeled I built a 5 gallon bucket into the head with a toilet seat over top of it. Then made a fastening system so the bag wouldnt fall in. At your local plumbing outlet they sell a product used to deal with the water in a toilet when replacing. It is a powder that absorbs the liquid and turns to gel. This works great for #1 and takes care of any odor for a few days. Sometimes I come back the next day to straighten up the boat if we were out late. If someone needs to #2 the bag removal and disposal is on them. it helps to have another 5 gallon bucket with a lid for a holding tank on that unfortunate day when someone needs it. When I was using a porta potty it didnt matter what I did. There was always a spill somewhere between the head and the dumping station. The bag just makes more sense for the day/weekend sailer. Drop it in the trash can at the ned of the pier.
bljones likes this.
  #23
Old 02-19-2013
rhr1956's Avatar
rhr1956 is on a distinguished road
Thank you all for your input. I am anxiously awaiting the UPS guy (or girl) to deliver the goods.
  #24
Old 02-19-2013
caberg's Avatar
caberg is on a distinguished road
We are going to leave our marine head installed in case a subsequent owner finds value in it. But, this upcoming season we will be doing the wag bags fitted into the head. Hey, if the Pardeys can do it, so can we.
Sailing with Lin & Larry Pardey
  #25
Old 02-19-2013
HeartsContent is on a distinguished road
The biggest challenge with a PP is capacity. Which is why larger boats have built in systems offering holding, pump out and overboard discharge and usually 10+ gallons. For lite use PPs are perfect and I used one for two years on my sailboat. They can get quite heavy when full so keep that in mind.
Also DO NOT get the type with the screw on cap on the bottom - these WILL leak. All the of the new ones have a solid bottom with a swiveling pipe to dump.
Heads are Heads and well ... they're nasty! There's no getting around it. :P :P :P
Currently between boats!
Dunedin, Florida
  #26
Old 02-19-2013
DRFerron's Avatar
The most female moderator
DRFerron is on a distinguished road
The original post seemed to imply that a bucket is the same as a porta potti. Not. A bucket's a bucket. At least a PP hides the excrement in the chamber.
I'd have problems with a bucket, too (unless every other system on board failed). I had no problem with the PP on our 22 footer.
Donna
Catalina 30
Rock Hall, MD
Contributing Editor
magazine
SSCA Rock Hall Cruising Station
  #27
Old 02-19-2013
mad_machine's Avatar
mad_machine is on a distinguished road
As somebody who has intestinal issues (crohnes disease) I would be unhappy with a bucket because I would be using several times a day (or a sail). They are also not as stable as a PP as they have nothing more than your weight holding them down to the deck.
Art Haberland
Be careful of your words, for someone will agree with them. Be careful of your conduct, for someone will imitate it. -Leih Tsu
  #28
Old 02-19-2013
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I remember one day after a lovely sail, sitting dockside, having a cold libation, waiting for the sunset. Then - five guys came down the dock, carrying their little briefcases full of - well, full of whatever they were full of.
Ruined the entire evening.
Hey, we were coming into an anchorage in the Caribbean and motored by a hard chined steel boat that looked like it had taken a few laps around the marble. The old guy on board walked out onto the swim platform on the stern, dropped trow', bent his bum over the water, and unloaded the remains of his unholy french cooking into the sea.
Bristol 27
Cirque
  #29
Old 02-19-2013
Scallywag2 is on a distinguished road
One summer I placed the chemical powder for the PP in the holding tank. I did not realize that the powder drifted onto my shorts. After an afternoon of sailing and sweating, I looked down to see that the chemical powder mixed with perspiration and caused holes in the brand new shorts I was wearing. Moral--Use a liquid instead of a powder in the PP.
Dot and John
  #30
Old 02-19-2013
PPPPPP42 is on a distinguished road
From a more technical standpoint every porta potty I have ever seen is amusingly enough the same size as the ones they sell for training children, as in freaking uselessly tiny.
I'm actually super skinny so its not a matter of width, but unless your a girl the bowl is a tad small for both #1 and #2 to make it in at the same time without serious awkwardness.
Guys can't use it standing up either unless you want it splattered everywhere (look at studies on pee splatter from standing height some time).
Then there is the matter of the comically small opening on the bottom of the bowl with usually almost no taper to the bowl and the lack of any sort of real quantity in flushing power. A cross wise #2 of any size and you are quite literally S.O.L.
And all is assuming you have no issue with cleaning it out.
So I would say on anything too small to have a decent size fixed toilet with a pump out its just not worth it.
You may post attachments
You may edit your posts
Chaninging from Porta-Potti to pump out cb32863 Gear & Maintenance 13 06-01-2012 02:58 AM
PORTA POTTI - A 'no no' or 'okay' for cruising? SailMonkey General Discussion (sailing related) 44 05-31-2012 11:23 AM
Porta Bote lancelot9898 Gear & Maintenance 8 03-03-2009 02:42 AM
Block Island, RI & a porta potti kwf05001 Cruising & Liveaboard Forum 11 04-24-2008 02:17 PM
porta potties? jbarros Gear & Maintenance 6 01-02-2003 06:41 AM
SEO by vBSEO 3.6.1
