Double or single lifelines? - Page 5 - SailNet Community
 7Likes
post #41 of 44 Old 02-20-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
Re: Double or single lifelines?
That might work. I guess I am not giving amsteel the credit it deserves. I seem to recall reading something a while back about the spliced eyes needing to be a certain size in order to not reduce the strength of the line (it was significantly weakened going around a small radius turn), is that still the case? If so then I guess I could just use a thimble.
Any suggestions for line for the lashings?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #42 of 44 Old 02-21-2013
I don't discuss my member
zz4gta's Avatar
Yes, any line of any material is weakened if it's bent around a radius smaller than what is recommended. For instance, most rope manufacturers suggest an 8:1 ratio. So for 1/4" line you need a 2" sheave, thimble, whatever. I can tell you that you probably won't need to worry about it breaking. The stanchions will absorb a lot of the shock load. I just splice mine to the ring on the pullpits or lash them there. I'm using 1/4" line which works really well. 8600 lbs breaking strength is a little much and I'll probably drop it to 3/16 when I replace it. But the stuff is cheap and easy to splice, it's not like it takes 1/2 a day to change them out, or longer like it would w/ steel.
I use spiderline for lashing. Dyneema core with poly cover. You can use "Lash-it" as well, but it's more expensive and doesn't hold knots as well. I would change out the lashing every year as cheap insurance. A mini spool is only $16.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #43 of 44 Old 02-21-2013
TakeFive's Avatar
Originally Posted by zz4gta View Post
...I can tell you that you probably won't need to worry about it breaking. The stanchions will absorb a lot of the shock load. I just splice mine to the ring on the pullpits or lash them there. I'm using 1/4" line which works really well. 8600 lbs breaking strength is a little much and I'll probably drop it to 3/16 when I replace it. But the stuff is cheap and easy to splice, it's not like it takes 1/2 a day to change them out, or longer like it would w/ steel....
8600 lb is probably more than needed, but before you go with 3/16" line remember that the tension on the line will be waaaay more than your body weight. You need to do the geometry here:
Also remember that the rated strength is for new line. As soon as it gets UV, weather, and chafe at the contact points, your actual tensile strength goes down.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #44 of 44 Old 02-21-2013
zz4gta's Avatar
My point is, the stanchions will fail before the line does.
zz4gta is offline
Which Crimp tool to use: Single or Double. Tree Electrical Systems 21 09-11-2014 11:52 AM
Single vs Double Spreader Tim R. Boat Review and Purchase Forum 18 08-07-2010 10:26 PM
transient dockline inventory -single vs. double braid? hazmat17 Gear & Maintenance 3 06-04-2010 09:51 AM
New Annapolis Single/Double handed race series Jeff_H Racing 1 04-30-2004 03:03 AM
