Like Tree1Likes
  #11
Old 02-18-2013
overbored's Avatar
overbored is on a distinguished road
Re: Adding 2" foam to v-berth bedding
I dont have v berth. the froli would be for the under cockpit berth where headroom is a premium. replacing with 4" foam means new upholstery. so it would be about $200 and reuse the 3"cushions I have . get better support and have air flow under the cushion. I may try this.
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #12
Old 02-18-2013
kellysails's Avatar
Puget Sound Pounder
kellysails is on a distinguished road
Originally Posted by overbored View Post
how thick is the foam you have on top of the Froli. the price seems to be less then new 4" foam
I already had 4" of a quality thick foam mattress. My initial concern was about ventilation under the mattress to prevent mold and mildew. I decided to go for a solution that provided ventilation and additional comfort, the Froli Star system does both well. It provides 1-3/4" of space for ventilation under the mattress and it was a significant comfort improvement over just the mattress alone. $279 for a standard V berth, not cheap.
  #13
Old 02-18-2013
Flybyknight is on a distinguished road
Been there, done that.
Buy the densest (most expensive) foam you can afford!.
5" preferred, but 4" will work.
Put a layer of foam carpet under-lament under your new mattresses.
You'll see why after you have done it.
Dick
You may post attachments
You may edit your posts
Replacing V berth foam material MarkSF Gear & Maintenance 35 06-11-2012 05:56 AM
Replacing foam on couches and V berth MarkSF Gear & Maintenance 5 09-09-2011 07:40 PM
V Berth Bedding alternatives TheRealBill Gear & Maintenance 23 08-20-2010 11:08 AM
adding a berth freddyray Sailboat Design and Construction 16 03-26-2009 09:04 AM
replacing foam in berth cushions wumhenry Gear & Maintenance 14 09-13-2007 10:55 AM
SEO by vBSEO 3.6.1
