Best small boat for cruising the Bahamas? - Page 10 - SailNet Community
 27Likes
post #91 of 168 Old 02-27-2013
bratzcpa's Avatar
Re: Best small boat for cruising the Bahamas?
In answer to your question, Kriscross, we have the "stock" water tank in the Catalina 27 of about 10 gallons (yikes, way way small).
Years ago, the PO removed the inboard motor. All of the motor mount rails, etc. are still in place. And it's kind of a crappy space for storage anyway. I mounted a 35 gallon plastic barrel in that space - basically right on the motor mount rails. Because it's located on the rails, it's just slightly higher than the regular tank, so I can use this to periodcally re-fill the regular tank - via a simple shutoff valve. It's also connected to a deck fitting for 1) filling with a hose at a marina, or 2) rainwater collection.
I like this much better than jerry cans on deck because it's out of the way (obviously), but it keeps the center of gravity very low too.
mark
~markb
S/V "New Girl" on the dock
Catalina 27
bratzcpa is offline
post #92 of 168 Old 02-27-2013
KNOT KNOWN
Capt.aaron's Avatar
Originally Posted by krisscross View Post
Thanks, that is interesting. Soverel 28 has a really low ballast to displacement ratio (under 20%), one I would never consider safe enough for open sea crossing. Have you ever run into rough weather in that boat? How did it do?
Oh jeez, I've been in gales in the Yucatan Channel opposing the stream . I've hove to in 15 footers stacked for 3 day's at a time. 8 foot draft board down and a bunch lead pigs in My bildge. I love the little boat. Taking it to Honduras non stop in May weather or not. I did a way with the spade rudder and put a Barn door on the transom.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #93 of 168 Old 02-28-2013 Thread Starter
krisscross's Avatar
Wow... that is pretty awesome... is your board actually heavy, or simply provides more lateral stability under those condition? Adding ballast to the bilge is a neat trick right out of old school ways. Have to keep that in mind. I take it you cast those lead pigs yourself to get the right size and shape?
krisscross is offline
post #94 of 168 Old 02-28-2013 Thread Starter
krisscross's Avatar
Yes, that arrangement makes perfect sense. So do you use an outboard now? What is your take on the practicality of an outboard on a boat originally designed for an inboard engine?
post #95 of 168 Old 02-28-2013 Thread Starter
krisscross's Avatar
Originally Posted by hamburking View Post
I had a Paceship 29 with a swing keel. Very good boat, shallow draft, and cheap to purchase. With only 2 people aboard...plenty of space. Good luck on your adventure!
Oh yes, that was a kicka$$ C&C design, solid as a rock. Would definitely consider it.
post #96 of 168 Old 03-03-2013 Thread Starter
krisscross's Avatar
What do you guys think about this Cape Dory 26 on ebay:
CAPE DORY 26 SLOOP , 1985 in Sailboats | eBay Motors
post #97 of 168 Old 03-03-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
from the pictures, it looks like a really nice, clean, well maintained boat. Looks like it would be worth a look.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #98 of 168 Old 03-03-2013
You should direct specific questions on the CD26 to the CDSOA, they are a great resource.
I'd be more inclined to purchase a CD26 over a CD25, mostly because it's an Alberg design and I really like the interior layout.
Keep in mind, you could probably get a 27, 28, or 30 for that kind of $$, though. I'd go aboard them all, see which you prefer. I'd think long and hard about looking for a CD30 with that kind of $$ though.
krisscross likes this.
Shinook is offline
post #99 of 168 Old 03-03-2013
The Cape Dory 26 on ebay looks excellent. I agree with the owner regarding the outboard. Honda outboards are great. However, you won't get the range of a diesel, or the battery charge. And you've got gasoline right next to your hot engine...yikes!
The Carl Albert Designed Cape Dory is an excellent boat...extremely rugged, built to take anything, and beautifully finished. The full keel design is meant for the ocean.
HOWEVER...this is a pretty small boat for that kind of money. For example, there is an O'Day 30 on ebay for $5k, with an inboard yanmar. Do you want to have a boat thats already done up, or some good bones and add your own equipment?
IMHO, in this economy, the cape dory is way overpriced for an older boat. And although I had a honda on the back of my C&C25 for years, I was pretty happy to get an inboard diesel on my current Pearson 30. FYI, my pearson30 has a good diesel, all new standing rigging, chart plotter, new sails, etc...and cost a small fraction of the Cape Dory on ebay. Also, florida is the place where boats are really really cheap (its the bottom of the hill, so to speak).
So, YES, you would be very happy with the cape dory, provided you are alone or are extremely friendly with your crew. No way around it...its a small boat. But if money is a concern...keep looking.
hamburking is offline
post #100 of 168 Old 03-04-2013 Thread Starter
krisscross's Avatar
Good posts... thanks guys!
Since most likely I will be sailing solo, I have to keep that in mind as well... small is beautiful when you are alone. I'm used to camping in my 20 foot Mirage, on top of a layer of gear and supplies. Money is definitely an issue but I want a solid boat that is already in good shape when it comes to all the important components - it costs way too much money to re-do all of them. Much cheaper to buy a boat that already has what you need.
This boat caught my eye because it is on a trailer and I can store it at home inland until I'm ready for the big trip (in about 2 years).
Another question:
Would you think this CD26 is safe enough for the Mona Passage and a Caribbean cruise all the way? This is stage 2 of my long term plans.
Getting a small boat to the bahamas Frogwatch General Discussion (sailing related) 14 02-04-2015 03:53 PM
Best Small Boat For Cruising the ICW ? ATWJMU88 General Discussion (sailing related) 4 11-29-2010 09:25 PM
your favorite small cruising (blue water) boat AmeriCdn Boat Review and Purchase Forum 46 08-19-2007 11:54 AM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 08:00 PM
Bahamas cruising in a small boat KPBaker Cruising & Liveaboard Forum 15 12-31-2001 01:05 PM
