Towing a boat on a trailer - SailNet Community
 2Likes
post #1 of 25 Old 02-22-2013 Thread Starter
So...I found a nice cat 22 on a trailer...only problem is its 200 miles away. I plan on purchasing a pick up sometime in the future but for now I have 2 Hondas incapable of towing. Enterprise does not allow towing but their ram 1500 has a hole for a ball. I guess it's called a bumper hitch. What would I need to do to attach the trailer? Just throw a ball in there with a pin? It says max tow capacity is 5000 and tongue weight 17 lbs
m2736185 is offline
post #2 of 25 Old 02-22-2013
T37Chef's Avatar
where are approximately are we talking? I'd be willing to help you out
Shawn
T37Chef is offline
post #3 of 25 Old 02-22-2013 Thread Starter
Re: Towing a boat on a trailer
Far from md. I'm in jax, fl. But thanks for offering
m2736185 is offline
post #4 of 25 Old 02-22-2013
My guess is that total boat & trailer weight could be about 4,500 lbs, maybe more. IIRC, in California, any trailer over 1,500 lbs requires trailer brakes. Suggest you find out what kind, if any, brakes are on your trailer. Also, I think most trailer Mfrs suggest anywhere from 5% to 15% of the total weight be on the tongue.
Using a rental vehicle for an unallowed purpose may be risky from both a liability and damage standpoints. The incremental difference between having it delivered and renting a tow vehicle may not be that much?
I towed a 6,000 boat and trailer combination and it can be a handful, especially in the wind. A big stout heavy duty towing vehicle is a must. I towed it once with my car, an old Detroit iron sedan, and didn't think I was going to make the short trip. VERY bad decision on my part, be careful
Paul T
dabnis is offline
post #5 of 25 Old 02-22-2013
T37Chef's Avatar
no problem ...just thought I would offer. check with U-Haul
Shawn
T37Chef is offline
post #6 of 25 Old 02-22-2013
Try Ryder Trucks for diesel vans. They may even have a tow package on the van, to give you trailer lights.
sony2000 is offline
post #7 of 25 Old 02-22-2013
Andrew Burton's Avatar
My car broke down right before I was to pick up my new J/80. I rented a Tahoe from Thrifty and got it that way. You will probably need an adapter for the lights. If you are careful, towing is no problem. Just keep it at 55 and stay in the slow lane. Use your mirrors and don't forget you have a somewhat longer load than you're used to.
Peregrine
C&C 40
Andrew Burton is offline
post #8 of 25 Old 02-22-2013
Barquito
Barquito's Avatar
I, also, understand that U-Haul allows towing. If you aren't in a state that requires trailer brakes, I wouldn't worry about it. Just be careful: Moderate speeds, maintain gaps ahead, check bearings for heating, strong tie-downs. For a few bucks more than renting a truck, you may be able to hire someone to haul the thing (with a pickup truck). In the long run, you are going to want to have something to tow the thing. Maybe just sell your car and buy a tow vehicle (Jeep Grand Cherokee would work).
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is offline
post #9 of 25 Old 02-22-2013
I've got a Cat 22 and use a 1/2 ton Dodge Ram as well as a Jeep Grande Cherokee. As long as the trailer is sound follow the advice already given and you should be fine. I would definitely check the bearings and tires. Some of the rental car companies rent SUVs so that would be a possibility. Where are you moving it from? I've got family in Jax.
copacetic is offline
post #10 of 25 Old 02-22-2013
I can only speak from my own experience, which includes driving an 18 wheeler. It is my opinion that if your trailer and boat combination weighs over about 2,000 lbs sooner or later you may be really glad your trailer has properly working brakes. You can be as careful as you can be but you can't control what others may do. Without trailer brakes the extra weight will increase your stopping or braking distance and there may be downhill grades to consider.
Paul T
dabnis is offline
changing tire on trailer with boat on trailer johnnyandjebus General Discussion (sailing related) 14 07-01-2012 06:09 PM
Towing A Boat casey1999 Seamanship & Navigation 43 01-15-2012 08:05 PM
towing and trailer questions lucianog General Discussion (sailing related) 5 02-03-2010 06:10 PM
Sea Tow vs. Boat US for towing in FL Keys? smallsloop Cruising & Liveaboard Forum 4 05-06-2009 01:17 AM
trailer sailor towing weight comparison chart? arbarnhart Boat Review and Purchase Forum 14 07-26-2007 01:22 AM
