Like Tree9Likes
  #1
Old 02-24-2013
boatboy132 is on a distinguished road
Installing stereo help
Hey guys, so i want to buy a stereo for my boat but never installed one and not sure what i need, there was never one on the boat before? has anyone done this
  #2
Old 02-24-2013
Re: Installing stereo help
Google is your friend!
Stereo Installation Tips | Boating Magazine
kellysails likes this.
  #3
Old 02-24-2013
chef2sail's Avatar
chef2sail will become famous soon enough
Not knowing what kind ( size boat) this is for and whether it is inside or outside installation its hard to say. If the unit will remain inside and nor be affected by the marine environement your best bet is to not spend the extra money for a marine on and go to get a good car stero one from Best Buy or a like place. If speakers are outside they need to be weatherized also.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #4
Old 02-24-2013
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
Listen to Faster and Chef2sail.
Also, make good electrical and speaker connections, for this you should search sailnet and do as Mainsail recommends.
When I bought the boat we had a car stereo and a 5 disk cd changer in her.
FWIW I didn't mount an antenna externally and find my fm reception to be fine most of the time using a small antenna below decks. Also, we use the iPod inside the radio probably 95% of the time aboard but you know your own usage I'm sure.
Here's what I ended up withRadio
Marine radio mounted below, wired remote to be mounted above (haven't done that yet as I have to order a new navpod) , speakers under the stern seats with heat shrink gel filled connections all around.
SV S.S.R.I
It's my happy pill
  #5
Old 02-24-2013
Originally Posted by Silvio View Post
FWIW I don't mount an antenna externally and find my fm reception to be fine most of the time using a small antenna below decks....
I've always had good luck running an antenna lead to a chainplate or shroud connection, use the rig as an antenna!
chef2sail and Silvio like this.
  #6
Old 02-24-2013
T37Chef's Avatar
Wood Cutting Board User
T37Chef will become famous soon enough
I'll second the use of a non marine stereo if mounted inside. the technology will change faster then the stereo will corrode. an iPod hook up and a remote control is very useful...even if the remote is infrared type.
chef2sail likes this.
Shawn
Tartan 37 - S/V Windgeist
Sailing the Chesapeake Bay
Photo by Joe McCary
  #7
Old 02-24-2013
jimrafford's Avatar
jimrafford is on a distinguished road
Also buy one w/ blue tooth so you can use your smart phone for music. It's nice to be able to control the music from the cockpit w/ your phone.
Jim
Silvio likes this.
S/V Deja Vu
CS 40
  #8
Old 02-24-2013
T37Chef's Avatar
hey that's cool...didn't know about the Bluetooth stereos
Shawn
Photo by Joe McCary
  #9
Old 02-24-2013
SHNOOL's Avatar
Usually sailing uphill.
SHNOOL is on a distinguished road
If I might suggest, inexpensive marine stereos exist aftermarket if you look... ebay, amazon, and buy.com...
Also, Shakespeare makes a VHF/FM splitter/sharer I just installed that works wonders for using 1 antenna for 2 devices. It forces a "switch" that turns off FM when you broadcast VHF. Seems to work pretty well.
Shakespeare VHF / Stereo Switch
I happened to find a radio that had no CD in it. Just used an SD card, or USB, with a single AUX port, of course with FM/AM. I think the whole setup, wire/speakers/radio/splitter worked out less than $100. It's not gonna wow an audiophile, but it'll crank out a decent amount of tunes.
Just make sure to put it on a fuse... DC is very easy to install. Red=+ Black=-/ground and life's good.
Catalina Capri 25, mountain lake sailed, trailerable, and PAID for.
  #10
Old 02-24-2013
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Here's an idea that you may not have thought of, and many will disagree with, but here goes: DON'T Install a stereo! Instead, buy a portable, battery powered radio (we used to call them "boom-boxes") and use that. They are: cheaper, easier to install, many are waterproof, you won't be putting unnecessary holes in your boat, you won't have to de-install when it breaks, you can bring it in the cockpit, on the beach, where ever you want...
Barquito likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
You may post attachments
You may edit your posts
stereo wiring QuickMick Gear & Maintenance 15 02-19-2010 11:07 AM
VHF and Stereo bartvdv Electronics 5 01-07-2010 04:19 AM
Small stereo zz4gta Gear & Maintenance 16 10-28-2009 11:20 PM
Stereo antenna MarkCK Gear & Maintenance 15 07-27-2009 01:29 PM
Stereo question SailChick20 Gear & Maintenance 10 03-05-2009 09:01 PM
SEO by vBSEO 3.6.1
