Outboard for Islander Bahama 28 - SailNet Community
post #1 of 10 Old 02-24-2013 Thread Starter
Iím looking for an outboard motor for my Islander Bahama 28 that will power my dinghy and provide backup for the inboard yanmar diesel. The boat has a displacement of 7,000 pounds and ballast of 3,000. Any suggestions?
tomdemott is offline
post #2 of 10 Old 02-24-2013
Re: Outboard for Islander Bahama 28
Most of the time, outboards to power sailboats need to be long shafts. And that's not what you need on a dinghy.
How big is your dinghy and how much motor can it handle?
Catalina 34
chuck53 is offline
post #3 of 10 Old 02-24-2013
We have a Cape Dory 27 with ~7,500lb displacement and we use a Tohatsu 6hp that works fine.
I tell some folks that and they look at me funny, but people love to buy massive outboards for their sailboats and generally don't need that much power. We actually run the motor at less than 20% throttle the majority of the time and it pushes us along at hull speed. In fact, we will probably sell it once we get an inboard and buy a 3 or 4 hp that's lighter and easier to take on and off the mount. Since it's our only source of powered propulsion right now, we're hanging on to it.
Shinook is offline
post #4 of 10 Old 02-24-2013
Tundra Down
downeast450's Avatar
I have used a 4 stroke honda 7.5, longshaft as the power for a former sailboat, a Rhodes 22, and now on our Marshall Cat. More than satisfactory for a light boat in fairly mild weather. I am glad I have the power of that motor on the small boat when strong currents are present. I would not trade an obm for the inboard in our 7,000# I-28. There are many times, given the boats potential range, having an inboard to help with the work and increase safety margins is the only thing that makes sense for me. Moving the boat around on a nice day. I suppose an obm would suffice.
That Honda is a hard working and reliable motor but I don't want to be using it to control the Islander. There are times when I wish the A=4 had a little more power.
Down
downeast450 is offline
post #5 of 10 Old 02-24-2013
bljones's Avatar
tell me more about the diesel and the dinghy. For example an 8' dinghy will be overpowered by an OB suitable for the Islander, and as previously mentioned, the shaft length is an issue, and a well maintained yanmar diesel will be more reliable than many outboards.
It's 5 o'clock somewhere:
bljones is offline
post #6 of 10 Old 02-25-2013
Time to feed. fellahs!
Anything past 9.9HP would be a waste of money. You're more or less limited by your hull speed which is in the 7 knots range so you'll use say 25% of a large motors power to get to 7 knots, 50 % to get to 9 knots and 100% to get to 11 knots. (I made up the values but you get the idea) At full power, the motor mount pulls off the transom and sends $4000 of motor to the bottom. So, I'd suggest getting an 8HP +/- 4-stroke. Check the motor mount manufacturer to be sure that it can take it. Electric start is nice and a take-off from the coil, to charge your battery. But, they're more money/weight too.
For the dingy (this is where the SN sharks begin to feed! Bring it!) Use a good sized trolling motor and battery, unless you cruise extensively. There's nothing like whispering up to the dock, or past a loon, sneaking by an egret fishing, or NOT waking the neighbors while you motor home from a romantic walk in the harbor town. I buy $100 throw away motors that last 5 plus years in salt water as opposed to paying $500 for a Riptide. If you prefer a gas motor, I've seen folks with 3HP Sears & Roebuck Gamefishers that do pretty well. But still, if you have the money, a small 4 stroke around 4 HP would do well here.
DonScribner is offline
post #7 of 10 Old 02-25-2013
FWIW our Tohatsu 4-stroke 6hp was $1500 new w/ a 3 yr warranty. It also has a small alternator, but no push start.
Not that you want to send it to the bottom, but there's no way I'd pay $4,000 for an outboard on a sailboat.
Shinook is offline
post #8 of 10 Old 02-25-2013
No, no, I was talking about putting like a 15 horse on the back expecting to hit 20 knots! A decent, new 8HP is about $2500. 'been lookin'.
post #9 of 10 Old 02-26-2013
Again, I wouldn't even pay that much. Most of the 2-strokes I was looking at were in the $600-$800 range, for 8-10hp.
If you want 4-stroke, you should be able to find a relatively new one for a lot less than $2500. I'm not entirely convinced 8hp is necessary, though. If you lived near me, I'd let you try it and see, but maybe you can find someone that'll let you strap the motor on and try it out?
Shinook is offline
post #10 of 10 Old 02-26-2013
tommays's Avatar
4hp will get you around just fine
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Islander Bahama 24 Music_man Introduce Yourself 3 02-13-2017 11:31 AM
islander bahama 24 gillwing Introduce Yourself 3 12-18-2012 08:45 AM
new islander 30 bahama in seattle merlinislander Islander 4 11-05-2012 04:57 PM
Islander Bahama 30 rlange Islander 16 05-14-2011 11:12 PM
80 Islander Bahama 30 NCountry Islander 1 03-29-2009 11:16 AM
