Ana Capri or Anacapri? - Page 5 - SailNet Community
 2Likes
post #41 of 56 Old 10-24-2013 Thread Starter
1975 Anacapri Erika 24
Re: Ana Capri or Anacapri?
Yeah the leading edge was the mystery component from your pictures (and my memory). The leading edge was the missing angle and I was just drew something to join the other angles. I wonder if I should cut that curve down to be straight so I get a more consistent airfoil.... I will have to play that by ear at this point. (I tend to over think things...)
Of all the pictures I took I cant believe I did not get any pictures of the rudder. Advice to anyone with a "rare" boat - get measurements and photos of all your odd components while you have one to look at. Capt Bill has learned lesson #243 the hard way!
We had a bit of an impromptu party last night at my woodworking friend house and cut and gorilla glued all the 2x4 rough sawn cedar. He even had a biscuit joint device and each joint has 1/2 dozen of those things in each joint. Then it will be for me to do a lot of sanding and shaping to NACA 012. I then have a gallon of resin left over to soak it with and then maybe probably I will cover it with some fiberglass.
The beers came out before the camera did so no pictures yet... I will try to update as I go.
Great idea on the rudder raising customization I think I will go ahead and make a hole for that while I am building it.
BillOcala is offline
post #42 of 56 Old 10-24-2013 Thread Starter
Originally Posted by 74anacapri View Post
I went a couple of seasons messing with mast rake to see if I could learn anything about balance and weather helm. My only conclusion was to keep a little aft rake and if I'm smart enough I can ok balance to either jib or genoa with main full or reefed. Any remaining problems are due to the skipper, not the rudder.
I wondered about that too. I did not have the patience to play with it on the failure day, but I am going to experiment with this later so I am ready for the next time. I should make sure that I can sail the boat without a rudder.
post #43 of 56 Old 10-24-2013
Originally Posted by BillOcala View Post
The beers came out before the camera did ...
LOL, how does that always seem to happen?? Nice to have a friend in the woodworking business at least.
You and I are pretty much neighbors, Bill! I live in Orange Lake, about 12 miles north of you.
dixiedawg is offline
post #44 of 56 Old 10-24-2013 Thread Starter
Hello neighbor! I just moved to Beverly Hills (closer to the ocean) and the boat is currently docked on Lake Wier until I get the bigger bugs worked out at least. Then then plan is to base out of Crystal River for awhile.
post #45 of 56 Old 10-24-2013
Very cool! I expect to be ramping my Catalina 22 primarily in Crystal River, too ... as soon as I get the bigger bugs worked out of her!
post #46 of 56 Old 10-25-2013 Thread Starter
Biscuits leaving voids to collecting water? We cut out my rudder blank tonight and we intersected some of the biscuits. I ask you, would you be concerned about water pockets here? They are white of course because gorilla glue takes over any space it can find!
post #47 of 56 Old 10-27-2013 Thread Starter
Slathered the resin on - hanging out to dry. It was a lot of sanding - but I started to get the hang of it towards the end. Belt sander was the ticket - just locked it on and played at being a sculptor. Might try it out this afternoon if I get really motivated.
post #48 of 56 Old 02-10-2014 Thread Starter
Several sails in the log now and the new cedar rudder is working perfectly. No need to fear doing this yourself, nothing to it at all!
post #49 of 56 Old 02-10-2014
Looks absolutely gorgeous, too! I want one!
post #50 of 56 Old 03-23-2014
Originally Posted by lil barby View Post
BillOcala
................. It was designed by eric goetz himself as a MORC, midget ocean racer, I never sailed it under,but can be overpowered in over 20..........
Could elaborate on this. Obviously this boat wasn't built in great numbers with mysterious origins. If you could shed some light on this it would be greatly appreciated.
rb
Randy Browning
Norwalk, CT USA
sonosail is offline
Capri 16 Termite Todd Introduce Yourself 0 01-14-2012 07:05 PM
Capri 22 magpie Racing 10 04-20-2011 11:15 AM
Capri 26 olie Boat Review and Purchase Forum 3 08-17-2009 09:19 AM
Who knows about Capri 14.2s? scottbre Learning to Sail 2 06-14-2006 07:49 PM
capri 30 noscreenname Racing 0 12-06-2005 12:29 PM
