Fiberglass Hulls Over Time - Page 2 - SailNet Community
 2Likes
post #11 of 12 Old 02-26-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Fiberglass Hulls Over Time
Originally Posted by Razcar View Post
This sort of thing is a gap in my understanding and thus the source of my inquiry. I see a lot of terms like this that describe the way a hull was built (in halves, in a whole mold, laid by hand, with a core, without a core, etc). It would be nice to see something somewhat comprehensive to describe that evolution. Most boats out there are old, and their builders chose a method of building which, at the time, may have been cutting edge, but over time proved to be terrible, for example. That's what I'd like to learn about.
except for a few lone examples (usually home built) all production glassfibre boats are built in a mold. It is the easiest and fastest way to build a boat. "hand layed" glassfibre is just that.. a gelcoat is sprayed onto the mold (after a release agent that keeps the gelcoat from adhering to the mold) and then a layer of resin is placed over the gelcoat and the woven glass mat is laid into mold by hand. A few layers of this and you have a complete hull, ready to be removed from the mold.
Chopper gunned hulls are started similarly, a release agent, then the gelcoat, then some resin is sprayed onto the mold and then the chopper gun is used. This chops up glass strands into smaller particles and sprays them onto the resin. A few more layers of resin and chopped up glass and you have a hull ready to be popped from the mold.
While handlayed glass sometimes leaves air and resin gaps, it is stronger because the weave of the glass better resists flexing and stretching. The chopped strands of a choppergunned hull do not have the integrity of the glass mat to fall back on.
Many builders use a hybrid. Structural areas will be handlayed glass mat and the rest will be filled in with chopped up glass to build up the hull itself
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #12 of 12 Old 02-26-2013
tommays's Avatar
There are pretty massive differences in the layup on my 1970 Cal 29 that seem to be fairly logical so IMHP there was some level of understanding
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Tags
epoxy , fiberglass , fiberglass core
cored vs solid fiberglass hulls MarkMiner General Discussion (sailing related) 32 02-21-2013 01:03 AM
Wood vs Fiberglass Maintenance cost/time Magaluza Gear & Maintenance 30 06-27-2012 08:48 PM
Fiberglass cure time wallybygolly Gear & Maintenance 7 02-13-2007 03:14 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 08:00 PM
