Halyard to Cockpit Challenge - Page 2 - SailNet Community
 4Likes
post #11 of 12 Old 03-03-2013
overbored's Avatar
Re: Halyard to Cockpit Challenge
it does not matter how many degrees the block is used to turn the line. 10 degrees or 180 degrees the friction from the block is the same. good quality ball or roller bearing blocks have very little friction and the larger the sheave the less the internal friction in the line. use one mast base block and an deck block or organizer at 90 degrees to the mast then back to the clutch with a fairlead to go over the raised section of the cabin.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #12 of 12 Old 03-03-2013
Originally Posted by snook91901 View Post
Yes
As Faster said, why not just bring it to a front corner mounted block and angle it off?
The best upgrade would be to bring the halyard down inside your mast. It's not as big a project as you might imagine, but certainly more involved than attaching a pieces of deck hardware.
Jeanneau 54DS
Minnewaska is offline
Tags
halyards aft
Center Cockpit Versus Aft Cockpit BlueWaterBlair General Discussion (sailing related) 58 03-19-2012 12:35 PM
halyard shackle letting go, spinnaker halyard interference ctlow Gear & Maintenance 13 05-23-2011 10:55 AM
Aft Cockpit vs Center Cockpit AjariBonten Boat Review and Purchase Forum 26 11-05-2007 01:53 PM
Center Cockpit vs. Aft Cockpit. badadim Boat Review and Purchase Forum 29 07-19-2007 07:44 PM
Suggestions on main halyard control from the cockpit. Dan Desjardins General Discussion (sailing related) 1 07-02-2006 10:44 AM
