Catalina 42 ... Why not? - Page 3 - SailNet Community
 27Likes
post #21 of 70 Old 03-04-2013
tommays's Avatar
Re: Catalina 42 ... Why not?
Pretty much every modern furling mast i have seen has a second slot for a storm sail and as i have seen plenty of normal sails a LOT worse off when used in winds that require that 3rd reef point
The strom tri would seem to be a prudent piece of gear on any offshore voyage and any type of mast
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #22 of 70 Old 03-04-2013 Thread Starter
All good points (I still remain skeptical from some experience with/ref in mast furling...)...
...but my other issue is with a wing keel...
A good salesman at the Miami Boat Show has me just about convinced I should go with a wing keel as first choice (fin keel was my original first choice)...
I like the shallower draft wing keel for coastal US, Keys and Bahamas and not too worried about 'loss of upwind performance' in a C42 as the owner reports indicate they do quite well with wing keel.....
BUT - how much more difficult is it to unstick a wing keel from a grounding vs a fin keel AND - the shallower draft of the wing affords less 'protection' for the rudder vs the deeper fin.
Thoughts?
malyea is offline
post #23 of 70 Old 03-04-2013
Are you sure you want to turn this into a wing vs fin keel debate? I think you may be better off reading a few thousand existing posts on the subject rather than rehashing it here. (In the end I don't think you will have a clear answer anyway).
JimMcGee and davidpm like this.
SteveInMD is offline
post #24 of 70 Old 03-04-2013 Thread Starter
Smile Re: Catalina 42 ... Why not?
Well sure, why not...??? There's usually at least couple new perspectives in any good ole' rehash
Fin keel vs wing keel for coastal US, Bahamas, Keys, Caribbean and maybe a crossing or two.....
Thoughts?
malyea is offline
post #25 of 70 Old 03-04-2013
OK...
The only people that will tell you that a wing keel works as well as a fin keel are people that own a wing keel, or have one to sell. If you don't care about upwind performance a wing keel will serve you just fine. Even on the Chesapeake Bay, (lots of shallow water) I glad a have a fin keel and I don't feel like the 6' 8" draft is a problem at all. The boats I used to race on usually had approximately 10' drafts, and one was 14' 6'. The point is that I think 6' 8" really aint that deep. (But many will probably disagree.)
post #26 of 70 Old 03-04-2013
OK...
I agree with Steve on this one even as a wing keel owner. I also hold the humble opinion that 6'5" is not excessive draft for a 42' boat, even on the Chesapeake. Heck, a First 36.7 draws over 7 feet.
Wing keels are a compromise and while they will perform "ok", they never out perform the same boat with a fin. I've only owned wing keel boats, and both of them exhibited fairly strong weather helm sooner than I would have expected. The fin keeled boats I crewed on seemed to have a bit more tolerance as the winds built. I'll tell you my boat sails ok and no worse than the many other shoal draft boats here on the bay, but if I could have the same boat with a fin, I'd take it.
Re: the grounding issue I feel the argument is both overblown and there is a corollary in that I believe, based on my experience, that a wing keel is likely easier to unstick if you run around while motoring since its broad bottom tends to bounce/skip rather than dig a groove. I've found the bottom many times poking around the creeks off the Chessy, and have always managed to manuver off fairly easily. Now if you sail yourself aground, I agree the wing might make life more difficult.
Spencechip likes this.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #27 of 70 Old 03-04-2013
KIVALO's Avatar
Dock
Everyone makes such a big deal over wing vs fin. I have a question regarding the two, how much higher will a fin point? How much faster is a fin?
Of course the answer, if there can really be one, will be approximate since every boat is different.
Thanks in advance
Brad
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
post #28 of 70 Old 03-04-2013
Thanks in advance
Brad
Take a look at the PHRF ratings to get an idea of the relative difference.
A C36 fin is roughly 15-20 seconds a mile faster than a wing keel C36 as rated by PHRF of the Chesapeake.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
post #29 of 70 Old 03-04-2013 Thread Starter
In a slight rum haze....but can we 'convert' that to ' x percent faster'...?
malyea is offline
post #30 of 70 Old 03-04-2013
JimMcGee's Avatar
Hmm, when cruising you're not going to be constantly tweaking sails to wring every last ounce out of her so the difference is -- drum-roll please -- negligible!
Offshore you may see some difference in leeway, in the Bahamas and Florida the draft may make a difference depending on where you go. Hell, where I'm sailing 10 feet feels like deep water.
It's a boat. Everything is a trade-off. It depends on where and how you want to sail her.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
1994 Catalina 320 vs 1992 Catalina 36 ChuckBuck Boat Review and Purchase Forum 8 01-10-2012 10:42 AM
Difference between an '88 Catalina 30 and a Catalina 30 MkII? dennismenace111 Catalina 0 04-07-2011 02:42 PM
Catalina 30 Keel cracks (not Catalina Smile) Pelham Catalina 5 12-01-2009 11:39 AM
catalina 34 Mark II or catalina 350 casey1004 Boat Review and Purchase Forum 11 06-13-2003 05:39 PM
