lightning protection - SailNet Community
post #1 of 5 Old 03-03-2013 Thread Starter
Whitewater to Seawater
Zoya's Avatar
I know the subject has been discussed at length on the forums but I have not seen anything on whether or not, today's boat builders integrate any lighting protection in their designs as standard? Do they?
Zoya is offline
post #2 of 5 Old 03-03-2013
outbound's Avatar
Re: lightning protection
To my knowledge many meet ABYC standards for bonding-after that you're on your own. May wish to look at website of a professor from Florida. Does business as Marine Lighting Protection. Also many folks use a grounding/lighting protection plate from Ward's an marine electrical supply house also in Florida. My boats in the past have not come with lighting protection.
s/v Hippocampus
Outbound 46
outbound is offline
post #3 of 5 Old 03-03-2013
Dirt Free
boatpoker's Avatar
French boats use a tinned braided copper from the shrouds to the keel bolts which is not ABYC compliant. On C&C 99's they use a solid copper conductor from a shroud rod to the fuel tank and then to a keel bolt and this is not ABYC compliant either.
There is little consistency or compliance in this area.If you name a specific boat you'll get a more specific answer.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #4 of 5 Old 03-03-2013 Thread Starter
Zoya's Avatar
Thanks boatpoker. I have a 2013 Beneteau Oceanis 41...
Zoya is offline
post #5 of 5 Old 03-03-2013
Dirt Free
boatpoker's Avatar
There will probably be a cable that looks like those below running from a keel bolt up under the liner to a (usually) starboard shroud rod plate.
I can do that
- wg
lightning protection soapstone Gear & Maintenance 3 08-07-2003 12:26 PM
Lightning Protection Sue & Larry Gear and Maintenance Articles 0 10-07-2002 08:00 PM
